Honeywell thermostat rvl450 err message
All other thermostats are working fine for my baseboard heaters. except for one that looks like it is working then I get an err message. Please help.
  • Michael Wood Dec 05, 2012
    I forgot to mention that this thermostat has not been removed or disconnected for 3 years. This happened after I took off the summer setting and tried to use the heater. Any possible information anyone has would be greatly appreciated.
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
SOURCE: marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Posted on Nov 19, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
How do I connect two baseboard heaters to a programmable thermostat?
You have switched 2 of the wires, reverse them.. If you had it working once, then it will work again
Apr 12, 2013 | Honeywell Heating & Cooling
Need a thermostat for model no hz-514
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
