Question about Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool model number MH9180XLQ-0 On then off then on
2 problems- When starting it goes on then off with a strange sound in the control area then comes on & completes the time until today it comes on then goes off & doesn't come on but sounds like the switch continues to cycle trying to come on;timer continues to run.
Another problem- when operating there is a vibration that is louder that normal. It sounds like it is coming from the upper part of the microwave. occasionally it stops but not for very long.
  • tracye333 Apr 27, 2009
    Microwave worked one day then the next it didn't. The timer still runs but the microwave clicks on & off, light & fan clicks on & off , on & off.
  • William Miller
    William Miller May 11, 2010
    Can you post a video with sound?
jsrock516
  • 5911 Answers
SOURCE: Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Posted on Jul 31, 2007
SOURCE: Whirlpool GMC305PD -- Thee beeps and won't start
Worked great!! I bought a new fuse for $4.50 and replaced it and the microwave works again....light is still not working but I'm ok with that!! Thanks!!!!
Posted on Mar 27, 2008
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
Posted on Apr 01, 2008
reg501
  • 413 Answers
SOURCE: Whirlpool Microwave
The magnetron has failed and has damaged the waveguide. This type of failure is generally unrepairable. First look in your owners manual for specific warranties, then contact Whirlpool and explain to them what has happened.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
I have a Whirlpool old model # RM278BXV-3 and it has started shutting all the way down when heating things up. Contol panel goes blank and quits heating.
Sounds like the control panel. All the other parts are just brute force parts and either work or they don't. Over heating components on the control board are the probable cause.
Dec 30, 2014 | Whirlpool Microwave Ovens
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door a burning odor was smelled. I also noticed a burned spot about a quarter inch in...
There is not any power in the door itself. However if the chassis has chipped paint or corrosion the RF from the microwaves magnetron will cause those bare metal areas to reflect the concentrated RF energy and cause sparking.
The only Whirlpool Microwaves that have been recalled, has a model number beginning with XC and had a green sticker on the bottom face area of the chassis where the door closed.
I have often been able to clean and paint the bare metal areas with the correct paint to stop the RF reflection sparks. Using the model number above it is white enamel "appliance paint" that you would use to paint the bare metal areas. A word to the wise.... do not sand outside the area to be painted. Otherwise you re-introduce your current problem post repair.
The model number you passed is missing the very last digit that would be from 0 to 7 (Eight models)
Thanks for choosing FixYa,
Kelly
Feb 21, 2011 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool mh6100xyb-0 stovetop lights quit working. I can hear the relays click but no votage at the bulb.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2010 | Whirlpool Microwave Ovens
Control panel and rotation work. Bad Smell like
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number.
Apr 06, 2017 | Whirlpool GT1195SH Microwave Oven
Buttons #3 & 8 on control panel not working
Sounds like your keypad has failed and you need the fan circuit repaired on the control panel.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Add to that about $75 for the keypad.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | Whirlpool GH7155XHS Microwave Oven
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool MH6130XEB/Q Microwave Oven Logo
119 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
