Asus laptop won't turn on beyond windows start up screen
Powers up, Starting Windows screen displays, then goes to a black screen with the cursor. If I shut it down with the power key, then start it up again, I get the option to repair windows, but it says it can't fix the problem. Tried restoring to an earlier time, haven't tried restoring to factory default as I don't really want to lose everything.
Alright you r fine...
do u have data on ur C drive?
Posted on Dec 03, 2012
  • cathy m Dec 03, 2012
    Yes I do....don't want to lose it if i can help it!
rickyostrom
  • 270 Answers
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Posted on Nov 30, 2008
  • 64 Answers
SOURCE: hp laptop keeps restarting
If the laptop is not popping up any windows before it shuts down it could be the built in heat protection, you can see if your fan has a lot of dust by turning off the laptop off and then blowing into the area where it pulls in air. If it is popping up a window before it shuts down disconnect it from the internet and see if it does the same thing, if it stays on while discod from the internet then run your antivirus if possibl.
Posted on Mar 07, 2009
  • 85 Answers
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
Posted on May 09, 2009
foxyreign
  • 52 Answers
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Posted on Jun 10, 2009
  • 118 Answers
SOURCE: I have a Sony Vaio PCG-FRV26 series laptop that
The main drive (C) being too full is an indicator that's your problem. Windows reserves space on your drive called a 'swap' file. It effectively takes hard drive space and uses it in lieu of RAM if you don't have enough available RAM to run programs.
If the computer doesn't have enough hard drive space to create the swap file then it won't boot up, as it will interpret the lack of available space as a failure to install the file and then try to reboot.
Luckily it doesn't install one when you're in safe mode. Try going into safe mode and restoring some of your hard driver space, as well as performing a cleanup and defragmentation of your hard drive, and chances are it will boot up.
As an alternative you might think about getting an external hard drive and using that for any new programs/music/videos/etc.
Posted on Sep 04, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
Asus eee pc turns on, screen goes blank
If you see the system screen and the cursor, the monitor is fine. You likely either have had your operating system corrupted (I dont know if your EEE PC has Windows 7 or a Linux distribution) or it's possible your hard drive died....but i would try the OS first.
NOTE....do you have a backup of the data??? because reinstalling your operating system will format and erase your data. So if you dont have a backup, you may want to take out the hard drive and plug it into another machine and see if you can make a backup copy of the data first
After that, you choose to boot from your Operating System Disk (Windows 7 disk) follow the prompts to format and reinstall your Windows.
May 31, 2012 | ASUS Eee 900 Netbook
Oresario laptop starts but goes to black screen with cursor
Windows is not starting. Try to start in safe mode and if you can, do a system restore back to when it was working.
If you can't do this, then you'll need to insert the system disk and boot from it and choose the option to repair your computer.
I suspect that you have corrupt Windows files or a corrupt registry. Repairing it with the system disk should solve the problem. Either that, or you will have to do a reinstallation.
Dec 14, 2011 | Compaq Presario C700 Series Laptop...
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
My asus p5vdc-x flashes the asus motherboard screen, beeps once, and then goes to an all black screen with a blinking cursor and doesn't boot up vista. It worked fine yesterday, when I started it up and I...
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Dec 02, 2010 | ASUS P5VDC-X Motherboard
Windows XP will not boot up. After Asus start-up screen, screen goes black with blinking cursor.
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk and an external cd unit.
Nov 24, 2010 | ASUS Eee PC 1000HE Netbook
My computer was frozen and I turned it off. When I turned it back on all I had was a black screen with a white cursor blinking. What is wrong and how would I fix this?
Nov 07, 2010 | ASUS Eee 4G Notebook
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
