Question about Sony DVP-NS710H/B DVD Player
Change region to pal on my lexdium lpd-900
My lexdium is pal/ntsc TV system, but when I set to PAL still doesn't recognize the region
SOURCE: PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Posted on Jan 02, 2008
worldvet
  • 859 Answers
SOURCE: how to unlock it to play either NTSC/PAL
Here is the sequence to unlock your DV Player. Clearly this needs to be done exactly to access the secret menu. So, you may want to copy and paste this info into a word program and then print it.
- Begin -
1. Turn off NS55P, leave TV on.
2. Using the original remote supplied with the NS55P, press these buttons in order: DISPLAY, TOP MENU, CLEAR, POWER.
3. NS55P will turn on, displaying the secret menu on the tv screen.
4. Select 2: Drive Manual Operation, then 4: Tray Aging Mode.
5. The screen then shows two input lines: Input Count and Current Count. Use the code 00030 on the first line. Pressing zero first will take you back to the original menu, so instead of trying to type 0-0-0-3-0, try something like 1-0-0-0-3-0 so the 1 in the front disappears after the last zero is entered.
6. Press ENTER on the remote. Disk tray will then open and close automatically 30 times. Let it do this until it finishes.
7. Repeat steps 4-6, but instead of using 00030 in the Input Count, use 00000. Press ENTER, and the NS55P is now capable of reading Region 2 dvds.
- End -
Please ask any questions using the comment box below.
Regards,
Worldvet
Posted on Jul 07, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Pal to NTSC
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
Posted on Jun 06, 2010
muntejaya
  • 10421 Answers
SOURCE: Hello, I am from Spain and I bought a sony
Hello, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_bnm89
Posted on Feb 27, 2011
muntejaya
  • 10421 Answers
SOURCE: I have a sony dvp-sr200p
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
Best Regards, Jay_i8u9
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
Sep 18, 2014 | Televison & Video
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
I am trying to play dvds from England (Region 2) on this dvd player and bought it specifically because it is region free - plays NTSC and PAL, so thought it would be an obvious choice. I can get the dvd to...
Are you in the US? Your TV system is NTSC. The player possibly plays NTSC and PAL(European system) discs on PAL TVs only. Try to find out from the user manual of the DVD player if you can change the output signal to NTSC. Now it is PAL even though you are playing NTSC discs.
Oct 14, 2013 | Pioneer DV-3032KV 1080P Upscaling Region...
I bought a 42TA648BX philips and now I want to use it out of the country with PAL system - how can I do so?
You can't.You can't used NTSC tv frequencies on PAL system.U should of bought a tv call regions free tv than u can used is on NTSC or PAL frequencies systems.
Sep 16, 2011 | Philips 42TA648BX 42 in. LCD TV
I need transform my samsung ht-tz212 to region free
First, in order to do what you're trying to do, you would need a device hack, a series of commands that break into the device's firmware in order to change the region code. This is possible for some players but pointless as the region code is only half the problem and if you unlocked it you would have to change the region code every time you used different Region Code DVD's and you can only do it a maximum of five times before the DVD player becomes a brick. Sites that offer region hack codes don't mention this fact or the more important issue of incompatible analog standards and it is very important to understand. It doesn't matter whether or not you hack your US DVD player's region code, it broadcasts (transmits) the NTSC analog standard to the television which displays the NTSC standard. All other countries outside of North America broadcast using the PAL analog standard and the two standards are not compatible. Non North American DVD's are recorded in the NTSC analog (look at the back of any DVD and you'll see near the bottom it will say NTSC) and Non North American DVD's are recorded in PAL. Region Codes are only security features built in by the studios to control international distribution that block media from being played, not from being displayed and have ZERO to do with the analog standard of a particular country. The media, player and the display must all have the same analog standard and your television does not support the PAL if you live in North America standard so region code changes don't solve that problem (and vice versa if you lived outside of North America). To do what you're suggesting, you would not only have to crack the region code but you would have to use a converter to change the format of your R2 discs from PAL to NTSC. Your integrated DVD player does not have this capability and few do. The only option that you would have would be to purchase a true multi region universal player that has built-in converters to convert from PAL to NTSC.
May 27, 2011 | Audio Players & Recorders
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    I have ntsc lg plasma tv i want to change it to pal tv
    U can't just change any tvs to NTSC or PAL regions at will.Does not work that way.U have to have a regions free tv,have a AUTO regions design in it circuitries,than the tv work in NTSC or PAL regions.
    Jun 26, 2010 | Televison & Video
    I want to play an NTSC tape on a PAL television
    This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
    May 28, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
    TV with PAL Only DVD
    No,tv is PAL or NTSC not possible to change region setting in tv.
    Dec 12, 2009 | Televison & Video
    Rf signal pal to ntsc
    there should be an option in your picture settings menu
    Jul 23, 2009 | Polaroid FLM-1514B LCD TV
    Sony DVP-NS710H/B DVD Player Logo
    174 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
