Question about Mtd 22" Yard Machine Push Mower
Broken off shear bolt stuck in snowblower
Hi
I have an MTD snowblower with only the right side turning. The left side has a broken shear bolt. I bought a replacement bolt, but can't get the shaft of the old bolt out - have tried using a hammer and a screwdriver to tap it out...
  • Anonymous Apr 01, 2014
    My blade sheared a bolt. Now the blade is sideways stuck in the deck
Hit the pin out with a punch and a hammer after drilling off any part of the pin that might be impeding your progress. you might also have to put some juice into your swings because a nail is too soft
Posted on Feb 27, 2012
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 11, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a 5/22 2 stage MTD snowthrower and from behing the machine, the right side auger is not spinning. The left side works fine, when the engine is off, the right side spins freely while the left is...
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Feb 24, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
Mtd 22" Yard Machine Push Mower Logo
676 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
