Question about Apple iPod MA446LL/A MP3 Player
Apple ipod Changed the lcd screen now have a white screen
I just changed the lcd screen on my ipod the old one worked but had a bad place in the screen. I ordered a new lcd screen and replaced it Now im not getting anything but a solid white screen even plugging up to my computer apple does not recongnise it Help Please. Email me at
    New Friend:
  • 24 Answers
Try to reinstall then reset. If that does not work than more than likely the screen is bad.
We may be able to help!
iPod touch 4th generation repair and replacement parts
Posted on Feb 25, 2014
    Problem Solver:
  • 11 Answers
1) You have not fitted the replacement screen properly
2) Something else has gone wrong - i.e. logic board
3) The screen is faulty.
Personally, I'd suggest removing and re-installing the screen.
Posted on Jan 16, 2009
My ipod screen is white cant see anything
Try resetting the iPod, by holding down the menu and the center button down for 10 seconds.
If this doesn't work, try restoring the device through iTunes.
If this doesn't work, you likely have a bad LCD or Logic Board. Send it into Milliamp for iPod Repair.
Dec 04, 2009 | Apple iPod nano
Ipod nano glass install
  1. Work in a clean, dry, and dust free area
    iPod mini - remove the top white plastic plate and the screws and retaining bracket beneath it with computer safe plastic pry tool and screw driver. Then slide the metal casing off, while placing light pressure on the center of the click wheel to disengage it from the casing. Slide the entire insides out of the casing, completely expose the inside of the ipod.
    All other iPods, remove the upper half of the plastic cover using computer safe plastic pry tool to expose the inside of the ipod.
  2. Now that you have exposed the iPod's innards, you should see the LCD screen in it's bracket with a single cable connecting it to the mother board coming off one side. Unplug the old LCD screen and set it aside.
  3. Plug the new LCD screen in exactly where you unplugged the old screen and place the new screen carefully in its casing or frame.
    *Now you can carefully plug in the iPod cable to test your work. If it is not working uplug the USB cable and check all your connections again, making sure the wiring is not twisting or pinched. Once you have checked and corrected the problem, retest it. (If it is still not working the LCD screen might not be your problem.)
  4. iPod mini - Carefully slide the iPod inside it's metal casinng, taking care to put gentle pressure on the click wheel to guide it into place. Then replace the retaining bracket and screws and replace the white plastic cover. Now you're done! Enjoy an iPod brought back to life.
    All other iPods- simply align the top panel and snap it back into place, being careful not to pinch any cables - or your fingers!
    Now you're done, and you have breathed new life back into your iPod for many more hours of fun watching and listening. Enjoy!
Make sure you purchase the exact screen you need. They can often be purchased online fairly inexpensively. Search around for the best deal you can get for your money.
  • Plastic tools specially designed for working on iPods can also be found for a few cents to a few dollars easily online.
  • Always work in a clean, dry, dust-free area
  • Always observe electrical safety precautions when working on electrical or computerized devices.
  • Remember that if your item is under warranty, working on it yourself may void the warranty, so if you have a pretty new iPod check with apple first to see if they will fix it for you for free under warranty!
  • Sep 27, 2009 | Apple Audio Players & Recorders
    SoundDock won't charge newer iPod versions
    Unfortunately there is no real fix for this. Apple changed the charging from USB to Firewire, so the old charging methods don't work anymore. I purchased an adapter somewhere on the internet that worked with some devices and not with others, but I can't remember where I got it from.
    You will either have to wait for apple to change it, or bose to find a work around, or get a new unit.
    Aug 21, 2009 | Bose SoundDock digital music system...
    White scrren on ipod classic but works on itunes
    Is your ipod still under warranty?
    If so make an appointment at your closest Apple Store and they will replace the iPod for you at no charge.
    If it is out of warranty, you may need to replace the LCD.
    If you have dropped the ipod the LCD could be damaged and not be cracked.
    Try restoring it in Itunes and see if that helps.
    If not Replace the LCD and you should be fine.
    If this helps please leave a vote on fixya
    May 14, 2009 | Apple iPod classic MP3 Player
    Replaced lcd get white screen
    If you bought the new 'super bright' lcd for ipods then this is the problem. The new 'super bright' lcds for sale on ebay are only for 6th gen ipods. Buy a 5th gen lcd and all problems will be solved.
    Mar 21, 2009 | Apple iPod MA446LL/A MP3 Player
    White screen on my ipod 2gb nano
    there are a few possible reasons for this
    1. the lcd screen is damaged.
    in this case the lcd screen would need to be replaced,
    check warranty and apple repairs
    2. the board or the cable between the lcd is broken or damaged.
    the lcd screen would need to be replaced or the flex cable, but that might be difficult.
    3. the ipod is frozen.
    instructions are at
    Let me know if you need anything else.
    Jan 13, 2009 | Apple iPod nano
    Apple ipod 30gb
    May i know whether your ipod is recognized on itunes??
    If "yes" Then you should try to restor eit to factory setting and check..
    let me know the results
    Jan 11, 2009 | Apple iPod nano
    I cant see the words nmy hp appe ipod screen!
    I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
    Nov 15, 2008 | Appel Apple iPod from MP3 Player
    Ipod nano 3rd gen 4gb
    this seems like a hardware problem, most likely you have to send the ipod in for repairs.
    you can try another reset and even attempt a restore from this page
    reset on the top, restore in the bottom.
    heres the apple service assistant
    heres also another place that might be helpful in repairs
    Jun 13, 2008 | Apple iPod nano 3rd Generation
    Connecting ipod to samsung lcd tv
    how to connect I-pod to samsung lcd tv
    Apr 03, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
    Apple iPod MA446LL/A MP3 Player Logo
    181 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
