Question about Video Game Consoles & Games
When i put my xbox 360 composite av cable into the back of my xbox 360 a red light appears on the front of my xbox??? can you tell me why and how do i fix this problem please
    New Friend:
    Problem Solver:
  • 5 Answers
Try turning your xbox from vertical to horizontal or vice versa and if that isnt working do you have any error code appearing on your tv screen or is is just the one red light?
Posted on Dec 28, 2012
5 Suggested Answers
  • 3 Answers
SOURCE: 4 FLASHING RED LIGHTS
4 red lights is not necessarily a hardware failure or ring of death. The cause is usually from AV cable not being detected or not connected correctly. The Eraser trick is good for Error 0102 make sure which error number you have! Suggested Solutions: 1. Try to connect and disconnect the cable and see if it makes any changes on the red lights status. Note that not inserting the AV fully will cause the 4 lights error to appear. 2. Make sure the AV Cable and the connector in the Xbox console are proper and there is nothing banded or twisted. 3. Try to connect it to a different monitor maybe this is where the problem is. 4. Find the metal area where it plugs into the console this is called the AV Pack metal area. Use a dry, lint-free cloth and wipe it. Then try to plug the AV again. * If you still can't make it to work and you have your warranty just send it in. If you don't have warranty I suggest trying the live chat support on Fixya!
Posted on May 28, 2007
SOURCE: e74 xbox 360 AV cable?
to fix the E 74 problem, i sudgest going to http://llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm. they have a step by step solution for both the red rings of death(3, and 1) or the E 74 error. i sudgest buying the kit they sudgest, its $29.99 or so. then just follow the step by step instructions when your kit gets to your house
Posted on Feb 24, 2009
SOURCE: Xbox 360 error e74
hey everyone.. MS will warranty this problem. here is the link that they are including the error e 74 to the list of coverage warranties.
http://www.thetechherald.com/article.php/200916/3451/E74-Xbox-360-error-now-covered-by-Microsoft-warranty
Posted on Jun 15, 2009
SOURCE: My Xbox 360 has four red rings
Unless some miracle happens, sorry to say, you earned the "Red Ring Of Death" achievement... Its most likely screwed.
Posted on Dec 16, 2011
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Ring of death 4 flasing red lights all at once says check av in manual. checked av cable i have hdmi and composite av cable and these were ok but problem persists
this is called GPU BGA solder cracking...a hardware failure that kills the 360 video functions... You need to repair this BGA with reflow techniques...reflowing the gpu with a smd air resoldering station, and a good flux...seach for 360 reflow videos on youtube...
Sep 11, 2009 | Microsoft Xbox 360 Console
4 red ligths on my xbox 360.
The AV cable cannot be detected
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Jan 18, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
4 red lights
Dec 26, 2007 | Microsoft Xbox 360 Console
4 RED lights
THINGS TO TRY for the ring of death!
Dec 13, 2007 | Microsoft Xbox 360 Console
Xbox 360
Hi, I hope something from below is useful to you...
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
If this is helpful in any way, please rate! Thanks
Nov 24, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
