Question about Avanti Kitchen Ranges
Avanti er2001g broken oven door
Left boor hinge
  • 641 Answers
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
Posted on Jun 05, 2006
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
  • 1314 Answers
SOURCE: Oven Door Hinge is broken Kitchenaid KERC507 range
at about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 20, 2008
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
Item comes with right hinged door...I need left hinged door.
On some models you can move the hinges and door pull to the opposite side. On the side without a hinge, you would see plugged holes (plastic plugs covering the holes). You may have to move the top right hinge to the bottom left and bottom right to the top left (opposite of this for a left-hinged refrigerator/freezer).
You may need help to do this, and be careful.
Donald
Jan 27, 2016 | Refrigerators
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Oven door hinge
Could you take a photo of the oven, the door and the hinges and show us?
Feb 14, 2014 | GE Microwave Ovens
Reverse hang door
Contact Avanti, they will have a kit with reverse hinges etc.
Nov 22, 2013 | Avanti WCR5403SS Compact Wine Cooler
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
How to replace left hinge on hp pavilion dv6 3019wm
These WEB sites show how to replace hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/ b>
Jan 10, 2013 | HP Pavilion dv6000z Notebook
Hing broke on copier can i get parts for that
Spare parts are available here (Brother MFC8440 Doc Feeder Parts).
Left hinge is one part, right hinge requires one or two separate parts
LP2403001 HINGE ASSY Left
LE6244001 HINGE BASE Right
LE6245001 HINGE ARM Right
Dec 29, 2010 | Brother MFC-8440 All-In-One Laser Printer
Kitchen Ranges Logo
57 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
