Question about GE (PSS26MSRSS) Side by Side Refrigerator
Coils in the freezer are iced up
I used a hair dryer to unfreeze the coils on the freezer part of side by side and plugged back in but is not working at all can you help?
  • 24 more comments
  • mikkee777 Jan 12, 2009
    no its not working
    I checked and no it is not working Thanks agin
    2001 model
    I didnt hear the compressor nothing is working except the ice maker i can hear it working but when i turn the ice maker off i dont hear anything else working
    I have seen the settings for the fridge and freezer and took off the caps but there is a small opening but nothing to adjust.
    what about the small fan by the freezer coils if that is not working would that cause the iceing up. or what about the heater element and where is it located?
    Yes it just started up the coils have frost on them
    just plugged it back in and tried to find the counter clock screws that you told me to turn and it started on which was weird because i plugged it in before i went to church and nothing happened. Now Duh its working. But if it ices up do you think i need the heating element replaced? And by the way thanks for your time and God bless you and family. Mikkee
    Where is the timer located i know a little but just rather ask than act like i know?
    thanks again Ken from mike in Az.
  • nadams25 Jan 12, 2009
    My side by side fridge is not cooling properly either. My ice maker stopped working because it's not freezing the ice. I use my freezer part for my fridge because the fridge part is not cold enough to keep my milk from spoiling. That is the exact model that I have down below. Cost to much to have a repair man come out and fix it. Does any one have any ideas? Please help losing money on food that is spoiling. The fridge is running just not cooling.
  • mikkee777 Jan 14, 2009
    It has been two days and my freezer coils are icing up again is this the heater element. Hope to hear from you again ken.
    yes
    I dont think it has a timer because it just has settings also pulled the heater element and the glass is cracked.
    no i dont see anything but a red cap with wiring that leads up to the fan but the heater bulb is craked in half that expains the icing up
    do i ohm out the actual wires or the heater element?
    i will let it defrost over night and look at it tommorow, and get back to you so i will check for that t-stat your talking about. Do all refridgerators have that t-stat? I really looked good and dont see anything else besides the copper lines and a silver line sodered on the copper lines but wed when i pick up the heater i will ask the techs.
  • mikkee777 Jan 15, 2009
    i put in the new heater element and its still icing up it is a dual heater so how often does the heater go on?
    i ohmed out the wires when its was plugged in and i get a reading but heater is not going on i have a duall heater and it has a wire on left side that plugs in two male leads so the directions told me to plug on right side both wires.
    Do i have to replace the temperture control board and is it hard to take out?
    I unscrewed the two screws that hold the temperture controls and i see the board is there anyway to test the board, and is this also have the timer in the board?
    No there is nothing but water line i even checked the back.
    there is a crome panel in the back and i took it off and i see a big circuit board.
    are you talking about the back panel board or the front temp switch. Also if i go to the appliance parts store and ask for the timer will they show me a board?
  • toddg5252 Jan 17, 2009
    I have a GSH25KGMB with the same problem. Replaced the heater and T-stat. Started to get ice once again and will be checking to see if the heater has blown again. I will also check the defrost control if I can find it.
    Thanks
  • Ken Bledsoe May 11, 2010
    Does the fan work inside the freezer?
  • 306 Answers
Also does the compressor come on? Get back with me quick if compressor isn't working I'm on the internet tonight so will be checking my email now and then. ken
The fan is the problem if the compressor is running just remove the back panel and the fan sits right there in the middle they are a little tricky to replace but take it slow so you can remember the way the bracket holds the fan. Remove the fan blades they are just press fitted on and go to appliance repair house and get a new one take old one with you and get the model number of frig and make.
Posted on Jan 12, 2009
  • 14 more comments
  • Ken Bledsoe Jan 12, 2009
    Do you have a ohm meter? Also there is a relay on the back of the frig called a PTC relay. How old is your frig?
    Can you locate the thermostat area? That is where you adjust the setting for the freezer and the fresh food compartment. There is a slotted screw driver in a recessed area in the same housing as the t-stat. Take your screw driver and turn the slotted screw driver screw I think counter clock wise. It will only go one way so use light pressure as this is the advance for the defrost timer. When you hear a click the unit should come on. There could be a chance that your timer is bad. Let me know how that goes. ken
    The fan has to run in order for the coils to keep from getting a build up of ice. You are right. And the heater is located on the bottom of the coils in the freezer when the back panel is off you can see one wire on one side of the coils to the right and one wire to the left. Thats the heater that aids in melting the ice that has built up on the coils.
    I'm afraid your unit is stuck in the defrost and since you have unplugged and plugged in that usually that resets the circuit board which I think you have on your unit it controls everything.
    But when I first read your problem I noticed you defrosted all the ice so I thought the compressor was working just not defrosting properly. Then re reading it I seen where everything is down.
    One thing it could be is the t-stat being bad but that is rare.
    (Just to make sure.) You sound very sharp and have some mechanical wits to you.
    And your thermostat is on at least 3 for both freezer and fresh food compartment. It's not sounding too good for a quick fixya that you might be able to perform. I'm leaning towards a repair man visit.
    There is one more thing the defrost thermostat inside the freezer compartment. That would shut down the whole unit should it open up. Can you check that with meter? Set your meter to ohm's and disconnect the two leads to the stat and ohm out. If it is bad you will not get a reading. That would make it act like stuck in defrost mode.
    What did you do>?
    Okay note the position that the screw is in it should advance in a 8 hour period your unit goes into defrost for about 20 to 30 mins. Then goes back into cooling. If it doesn't advance then the timer is bad. And needs to be replaced. As long as the fan works inside the freezer compartment you might be able to get by for awhile by either turning off frig for one hour every two days or what ever is going to work for you. But a new timer is needed. and god bless you and your family. ken here in kansas
    When you turned the screw that is the center of the timer. Just remove the wires and take timer off. You already have to cover off should be able to see the Phillips head screws holding it to unit. Should only have couple screws holding. Replace only if it doesn't advance, sometimes they get stuck and when you advanced it might be good to go now.
    Also your heater is okay forget to mention that earlier.
  • Ken Bledsoe Jan 14, 2009
    There is a t-stat on the coils that helps in defrosting the unit. Certain temp. and the t-stat opens and allows the compressor to quit and de-ice coils. I helped a person on this web site and we went through the same thing you are going through. Finally the guy was a transmission tech. and he was very sharp he was the one that actually figured it out. Do you have a ohm meter?
    Good if you already have the back panel off look at your coils and look for a round disk attached to the coils it will be about the size of a large quarter. Once you locate it and the unit has been running and icing up. Unplug the frig and pull the wires off the t-stat you found on the coils. Should have two wires. With your ohm meter in R for resistance check for resistance across the stat if you get a reading it's bad and needs to be replaced.
    One more thing has the timer advanced during the last couple days?
    hi there Mike I looked up my past problem with that one I just told you about and the clue he got was. Look at the t-stat in your freezer and if it is puffed out then it is bad.
    No defrost t-stat? Attached to coils.
    yeah you are right, just wondering how it got cracked. Inside there is nothing that would do that. Maybe the ice built up so much that just the force of the ice did it.
    Did you ohm it out? Should have resistance because it is a heater for the freezer.
    ohm the wires. No not all frig's have defrost t-stat's. Get back with me let me know.
  • Ken Bledsoe Jan 15, 2009
    Heater is good. Now the only thing it can be is the defrost control. And you must have a circuit board that does this. It should go into defrost every 8 to 12 hours for about 20 minutes using the heater to aid in heating up the coils to clear ice build up.
    Mike could you look under your unit remove the grill down by the floor in front of the unit. It is just snapped in place. Look for any electrical looking item. What I am thinking is this might be where the defrost control is located. It has 4 wires going to it generally square in shape. If will be easy to see as this is a common problem on unit's as they get older. You might have to get on floor and use flash light to see the clips holding the front panel on.
    That is what controls the defrost cycle it's all timed. Circuit board no defrost timer. Do you see on the board a it's going to be small but a jumper wire that says something like test bypass it will have very tiny pins that you jump the defrost mode it's like a test that a tech would do to determine if that part of the board is working or not. This is getting a little hard for me to describe as everyone of them are different but the same if you know what I mean.
Why did my refrigerator quit working but the freezer side still works?
Your freezer is probably froze up with ice. Pull all your food out of it and shut off the refrigerator. this will let the coils warm up and melt the ice.on the freezer coils. There are coils behind the freezer that freeze up up. I ran a hair dryer in there freezer on low for a few hours to speed up the process.
Aug 06, 2014 | Whirlpool Refrigerators
Model EP1chexbq00 no airflow on bottom: top freezer works but not bottom. Fan works.
Ok one of two problems. Either you have an ice block or you have a plugged drain. If you have a couple of dif choices. If you have a back up fridge than fill it with the contents of the broken one. Unplug leave doors slightly open for about 48hrs. Have towels for the water from the ice. Usually 2 or 3 bath towels. Plug back in and if the problem happens again within a week than your bi-metal ( defrest thermostat) is bad. To replace you have to remove the back panel in freezer and and on the condenser coils near top you will see a little round silver part.
Option 2- If no backup fridge or you have time. Have a hair dryer, 3 bath towels, a 1/4 inch nut driver (may be phillips) for screws. Unplug fridge and open freezer. Remove contents and place in ice chest with ice.remove screws from back wall pull panel forward. If you have an ice maker ther are two screws on the top where the ice fills at and one at the bottom. Also disconnect the quick connect for the ice maker. Remove back panel. You will see one of two things either all your coils are iced up (frost on all coils is normal) or two where it drains on silver plater has ice blocking drain hole. If ice is blocking drain remove and pour hot hot water down drain until it flows into drain pan in the back of fridge by compressor. If the coils are all iced up have towels ready. Start by putting a towel where it would normally drain where the towel is soaking up the water. Turn hair dryer on and melt ALL thee ice. some ice will be in the middle of coils and in back where you Cant see. Keep the hair dryer moving sitting in one place too long can damage wire and the walls of freezer. Melt all ice until no more water is falling from condenser coils. Than you will have to replace the bi metal. Put everything back in and plug in wait about 2 hrs before putting contents back in freezer. Just to let you know the the fridge will NOT cool down until freezer gets down to temp. Than the air will start cycling into fridge. If you have anymore question please feel free to comment me back for further assistance.
Jun 05, 2011 | Whirlpool Refrigerators
Frost on back of freezer does not seem to be cool enough
Sounds like a defrost issue. The frost is caused because the defrost element heater is not working. Ice accumulates in the coils and blocks the air flow in to the freezer/refrigerator. GE refrigerators have an element heater behind that back panel under the evaporator coils. They are quite simple and inexpensive to replace. Use a hair dryer to defrost the coils to make the swap easier.
May 23, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Refrigerator and freezer are not cold
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 57029 Side by Side Refrigerator
My maytag bottom freezer works but the fridge is not cooling all of a sudden. Just had the compressor replaced
Nov 12, 2009 | Jenn-Air JCD2389G Side by Side...
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
My Model ED5HHAXVQO2 REFRIGERATOR IS NOT COOLING. THE FREEZER IS NOT FREEZING BUT IT SEEMS TO BE BUILDING UP FROST.
Sounds like your auto defrost is not running long enough to melt the ice that develops on the coils. You can easily fix this problem by using a hair dryer and removing the back panel in the freezing unit to reveal the coils. Once this panel is out use the hair dryer to melt the ice. Once the ice is cleared this should restore air flow across the coils. Hope this helps. Good luck.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Coils ice up/over
I can think of three reasons why your freezer would be icing over. One reason may be that you have a low charge of refrigerant. The lower pressure that your freezer is operating has resulted in a lower temperature refrigerant being circulated. Another reason, if you have forced air circulation, is that one of your evaporator fans have gone out. The third reason I can think of is that your door does not have a good seal and moister is condensing, then freezing near the coils.
Feb 17, 2009 | Maytag MSD2758G Side by Side Refrigerator
My kenmore side by side is not cooling model 106.51574200
Now that really helps the one of two things it can be is the freezer compartment has the coils up there. They are more then likely covered in ice. Ice insulates the coils as to keep air from moving across them to remove heat from system. So take the back panel off in the freezer compartment and notice the shape of the coils. If they have a lot of ice built up on them unplug unit and get your hair dryer out to aid in defrosting unit a little quicker. If the drain tube located in the middle is plugged up with ice take some table salt and pour on the top. Only a couple a table spoons would be enough. let me know
Dec 03, 2008 | Kenmore 53642 / 53644 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
569 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
