Question about Ted Baker Te3004 Gents Bracelet Watch
How to get the back off a ted baker watch
How to get back off
Changing battery on TE4027 watch
Pl don't try yourself better visit a well experienced watch maker to replace it otherwise you will finish with worse
Jun 23, 2012 | Ted Baker TE4027 Watch
Just purchased a gold ladies 1928 watch. No instruction manual with it. Is it a manual windup or battery operated watch? Need instruction manual or booklet also.
Hello Ted,
Can you please specify the the Brand and Model of the watch? If you don't know it, just specify all the markings you can read from the watch.
Thanks.
I'll be waiting for your reply.
Nov 16, 2011 | Watches
Bulova watch Number on case is H663715. It also has an N1 which I think is 1971. But what is the model of the watch? Thanks.--Ted
Tough to tell from the little info you have provided but it may be an Accutron, the famous tuning fork watch, first watch on the moon (Omega was the first watch worn on the moon). You are correct about the date, N stands for the 1970s and the 1 signifies which year in the decade. Hence 1971. If the hand setting is done by a flip up knob on the back, it is the first of the Accutrons, the 214. If the crown is at the 4 o'clock position it is the subsequent 218. Both collectible but very hard to find parts for and very expensive to repair. Michael
Mar 28, 2011 | Watches
How to open the back
Determine the type of case back on the watch. Set the watch face down on a soft surface and look at the back. If it has slots, it is defined as a screw-back case. If it is smooth, it is defined as a snap-back case.
To open a screw-back watch, use the metal blade of a standard screwdriver to turn the slots counterclockwise. A case-back wrench, which can be purchased at watch-repair stores, can also be used. Set the metal tips of the wrench into the back's slots and turn it counterclockwise to open.
For a snap back case, place the metal blade of a standard screwdriver in the indent between the watch and the case. Gently apply pressure to lift the case up and off of the watch.
Close the case back by setting it back onto the watch. For snap-back cases, line up the indent on the side of the watch and press gently on the case back to close. For screw-back cases, use the screwdriver blade or case-back wrench to turn the slots clockwise, thereby closing the case shut.
Feb 06, 2011 | Bulova Watch
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    Where can i get instruction for a citizens navi sail stars and s
    You can download the instructions for your watch from the Citizen website here: http://www.citizenwatch.com/COA/English/settingsresults.asp?caliber=c320
    And... Thanks for your service to the country!
    Apr 30, 2010 | Citizen JN0040-07L Wrist Watch for Men
    Brand new watch running way to fast
    If this is brand new watch, the best way is to bring it back to the dealer to get it fixed under warranty or you will have to pay if the warranty expires. And watch repairs are quite costly.
    By the way- there is no reason to panic yet, as this sort of mechanical failure happens from time to time even to brand new watches.
    The reason of this can be:
    1) Watch has been magnetized,
    2) Watch hairspring has some dirt particles sticking onto it,
    3) Hairspring can be greasy,
    4) Jewel holes are not oiled properly,
    5) Uneven coiling of hairspring,
    6) Index hasn't been regulated properly.
    I understand that all this sounds a bit too scary, but in fact it is no big deal and any decent watchmaker can fix all this quite quickly, so, do not think your watch needs a complete rebuild or similar action.
    About removing that screw: There must not be any screws in the winder, but as I do understand, your watch has a screwdown crown (winder) and you have to unscrew it prior setting hands or date. Screwdown crowns are very nice feature as your watch gets very good water resistance, just don't forget to screw it back on.
    Don't forget to rate, please.
    Jan 04, 2009 | Ebel 1911 9125241/10665P Wrist Watch
    Ted Baker Te3004 Gents Bracelet Watch Logo
    69 people viewed this question
    Top Ted Baker Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Ted Baker Watch Expert? Answer questions, earn points and help others
