Question about Kaspersky Labs Kaspersky Anti-Virus Personal 5.0 (KL1101NDAFS) for PC
The file 'klif.sys' on Klif Source is needed
  • 28 Answers
Go to this website
http://support.kaspersky.com/
then go to Utilities tab and download Kaspersky Update Utility
run the program
Posted on Dec 22, 2012
Connect X 600 Edifier 2.1 Speaker Sys to Samsung, 40'' D550 LCD TV
Just follow the instructions contained in the operation manuals of both the devices.
Jul 11, 2012 | Televison & Video
Gateway dx4720-03 error 651 can't connect to internet
hello,
This error"Error 651" is caused by this file raspppoe.sys you can find it in c:/windows/system32/drivers/ rename it(raspppoe_something.sys) and copy the new file from a friend pc that runs vista .
Jun 10, 2012 | Gateway Computers & Internet
Often corrupt files in file manager, why did this happen?
Hello, Nice question, pretty easy. Sounds like you were messing around I'n the registry. Not good if your not sure what's happening I'n there. You got Several options: the 1st & the easiest is a system Restore. START-->PROGRAMS-->ACCESSORIES -->SYS TOOLS-->RESTORE follow the instructions to a point before the problem started. Your next option is a registry cleaner. Good Luck
Nov 27, 2011 | Sony Ericsson Cell Phones
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
A file rtkvac.sys for realtet AC97 is missing
Hello. You can download the file (rtkvac.sys) by entering THIS link.
Note that the link above contains a .zip file.
I hope I helped!
Thank you for using FixYa!
If you have any other questions please leave a reply!
May 28, 2011 | Computers & Internet
I am not able to activate my M Audio Delta series Audiophile sound card. It is asking for delta.sys file
Uninstall the driver of the sound card and carefully install it again. If it does not work again download the driver from the internet the source may be lacking the file delta.sys.
Good Luck!
Oct 19, 2010 | Computers & Internet
Has error bhdrvx86.sys address 8cc82837 base at 8cc5f000 then goes to a blue screen or restarts itself.
blue screen is a fatal warning in computer software, meaning the hardware setup is lacking or some shared file was deleted, on your laptop then press f8 then click safe mode, in your anti virus delete or clean bhdvrx86.sys ok or ----&gt; http://www.bestspywarescanner.net/errors/BHDrvx86.sys.html &lt;---- learn more<br />
Aug 27, 2010 | Compaq Presario CQ60-220US PC Laptop
When i turn on my computer i get File nvrd32.sys not found....
nvr32.sys is a NVIDIA nForce RAID Driver, this driver essentially controls your hard drive in connection with the motherboard.
If you are able to boot into safe mode (pressing F8 during start up until the option becomes available), then you should be able to install the drivers
Inspiron 6000 Drivers can be found here, look for Chipset:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid
If this does not work for you then you will most likely need to re-install windows.
Sep 29, 2009 | Dell Inspiron 6000 Notebook
How do I fix spooldr.sys?
Just clean it up, cut its nuts off and sew it up.
What makes you think it's broken?  You could examine the file with a hex viewer like that in IrfanView, replace the file with a fresh or backup copy, or recompile it from source; but assuming it's crashing, it might just be some bad control data around (e.g. if you were printing when your PC crashed) or a malformed print spool file you can delete.
     Just run your antivirus programs (see sourceforge and avg for free ones) as usual, but try 'use printer offline' and editing the spool list (print queue, whatever you want to call it) or running debug software to see what file goes in juuust before spooldr.sys crashes.
You miscategorized the problem as being for all PC Desktops when spooldr.sys is specific to something you hold more uniquely, by the way; a particular version of Windows (not XP) or your HP printer.
Jul 27, 2008 | Computers & Internet
Kaspersky Labs Kaspersky Anti-Virus Personal 5.0 (KL1101NDAFS) for PC Logo
106 people viewed this question
Top Kaspersky Labs Computers & Internet Experts
Tony
Dave Harris
Dave Harris
Are you a Kaspersky Labs Computer and Internet Expert? Answer questions, earn points and help others
