Question about Mitsubishi WS-65611 65" Rear Projection Television
What is the best way to conect a HDMI output Blueray player to a Mitsubishi WS--65611
The Mitshibushi has no HMDI inputs
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I would Go Component instead if possible---there are adaptors for the HDMI but you are likely to have issues that way as well.
Posted on Dec 03, 2012
  • 1153 Answers
SOURCE: Mitsubishi WS-65611 Blinking lights.
You are probably talking about the FMT board. I think you can have this board repaired at PTS 18008447871
Posted on Mar 13, 2008
SOURCE: Mitsubishi WS-65611 power and volume problems
yes...then what?
Posted on Apr 12, 2008
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
Posted on Jun 08, 2008
  • 11800 Answers
SOURCE: I have a tv model # WS-65315. I would like to know
No, your tv is strictly a Standard Definition one. Even it can receive a HD signal, it is downscaled internally to SD so the image would look exactly like from a low quality dvd player (that's because the internal converter is a cheap one) For best image quality use the converter from the BluRay and the Component connectors.
Posted on Nov 29, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65611 has a blurred image
The model number you have posted does not have a color wheel at all.
If it is WS-65611 go into the customer menu and select convergence--if it is 3d and will not adjust there--you have a convergence problem.
I HAVE AVAILABLE START TO FINISH, STEP BY STEP INSTRUCTIONS for replacing this part in this set--available here for free.
If someone told you it is a color wheel and you have the correct model number here posted--they are not very smart--this model does not have a color wheel and the later Mitsubishi sets that did have one--they do not sell the color wheel for them.
If you want the instructions let me know and I will post them here for you. I have repaired hundreds of these sets and the instructions are based on actual experience doing this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 15, 2009
Testimonial: "Thank you so much. If you could give me those instructions I would be very appreciative. You have been much more helpful than Best Buy!"
How do I connect my TV to blueray
plug blueray device output into hdmi input of tv and then change input select on TV to HDMi 1 or HMDI 2 or HDMI 3
Dec 17, 2016 | Televison & Video
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Jan 04, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Cant go from 480 i to 1080 any suggestions?
How do you have your Blu-Ray player hooked up?
First, you have to set your Blu-Ray player to output 1080i (the highest resolution that the Mitsubishi WS-55511 can support). Then you hook up the player via component to the DTV component input on your set (it's the only input that can handle 480i/p and 1080i).
Good luck.
Danny
Dec 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
