Question about Dell Precision 690 Motherboard
Dell 690, power button does not work
Dell 690 power button does not turn on computer, but if i remove cmos battery for 5 seconds then replace pc powers uip automatically, any suggestions?
  • Dell Master
  • 7,733 Answers
Your MB is fried.
Posted on Dec 06, 2012
5 Suggested Answers
  • 1027 Answers
SOURCE: Can´t turn on the notebook. After holding
Battery dead, power input dead, motheboard dead. Take your pick.
Posted on Jun 16, 2010
  • 263 Answers
SOURCE: No power after 5 second
Check the cpu fan and fins are clean if you have to take processor out make sure you reapply thermal compound, Also check the ram is seated correctly.Also check the psu is functioning correctly as it could be a faulty psu . Good luck John
Posted on Aug 02, 2009
  • 24 Answers
SOURCE: Dell 4150 will not use AC power
Only way is to open it up and check that you're AC connector on the board is ok. If that's fine than it might be the charging circuit.
Posted on Jun 03, 2009
  • 320 Answers
SOURCE: i am using a dell
several things could cause this problem your power cord may not be supplying enough voltage or amperage or both. the ram could have been compromised or the hard drive may not be initializing. i would look at the motherboard last. illiminate the easy stuff first. check voltage level on your ac power supply. try different ram open the hard drive bay and make sure it is comming up to speed.
certain thing happen in a given order during the boot process. the bios loads so the start up starts it loads to the ram and bring the hard drive up then video. your unit is stopping in the very beginning of these steps. follow these steps to isolate the cause.
Posted on Nov 06, 2010
Led indicator lights
Following are the various ways to clear the CMOS or NVRAM on Optiplex systems:-
The computer must be disconnected from the electrical outlet to clear the CMOS setting.
Remove the computer cover.
Locate the CMOS battery on the system board.
Note the orientation of the battery, usually the plus side is up, and remove it.
Wait for 3 to 5 minutes for the CMOS to clear.
Replace the battery in the socket.
Replace the computer cover.
Plug the system and devices back into the electrical outlets and turn them on.
And Sec option jumper setting also available you can used:-
Turn off the computer and disconnect the power cable from the electrical outlet.
Locate the 3-pin CMOS jumper (RTCRST) on the system board.
Remove the jumper plug from pins 1 and 2.
Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
Replace the jumper plug on pins 1 and 2.
Close the computer cover.
And More Support see link:-
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-755_user's%20guide_en-us.pdf
If more Technical Support Call.
Aug 22, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
Elimination of power flee on desktop computer
Can you rephrase the Question? "Elimination of power flee"?
May 09, 2013 | Dell Inspiron 530 Desktop Computer
I need to reset cmos password for my Dell D340 my computer system number is #BZ6X33J-595B please help. Msizi
dells not gonna do **** for you.
removing the cmos battery wont work on these dells
again,
here's the pw for your computer:
jqhuulq3
Jan 04, 2011 | Dell Latitude D430 Notebook
P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is the hardware component of a computer that supports the BIOS, or basic input output system. The two terms are often used interchangeably, and the two technologies work together to perform the same basic function. They maintain the low-level settings on a computer, letting the computer know, even before the computer's operating system starts, what kinds of hardware the computer has available, such as hard drives and video display adapters. A special battery located on the computer's motherboard powers the CMOS. To reset the CMOS on a Dell computer, briefly remove and then replace the battery
  1. Turn off the computer. Disconnect all cables and detach all devices, including USB devices, from the computer. Press and hold the computer's power button for 10 seconds after it has been unplugged. This grounds the system board.
  2. Step 2 Remove the computer cover. All Dell systems have a cover panel on the chassis that you can remove so that you can access the system's motherboard and internal components. For some Dell computer lines, such as OptiPlex, the computer cover is held in place by a release latch located on the back of the computer. Pull the latch to release the cover and then slide the over up and away. Other lines, such as Dimension, have large, slotted thumbscrews. Turn the screws counter-clockwise until they disengage from the chassis, the slide the cover off the computer. Dell computers often ship with the computer's user guide in CD form or with the guide pre-loaded on the system's hard drive. You can locate the instructions for removing the cover from your particular system in the user guide.
  3. Step 3 Locate the CMOS battery on the system's motherboard. CMOS batteries range in size from size and thickness from about the size of a nickel to about the size of a quarter. The CMOS battery will generally be labeled CMOS on the motherboard and will be the only battery openly exposed on the motherboard.
  4. Step 4 Remove the CMOS battery by prying it gently up out of its socket. The sockets are specifically designed to allow the battery to be replaced.
  5. Step 5 Wait 30 seconds, and then replace the battery in its socket. This will reset the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | ASUS P5RD1-V Motherboard
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
What does the bttery control? Can I remove it for 5 seconds,then replace it and solve the ITHR checkpoint problem ?
if you are referring to the round battery on the motherboard, it controls the cmos settings remove this and your PC will not boot. yet clearing your cmos may help. look for the lil jumpers usually located near that battery and change them to reset, power on let boot then power down. then place them in the original slot.
Aug 10, 2009 | Dell Dimension 3100 PC Desktop
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Jun 11, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Jumper location motherboard blade 2, dell latitude x300.
The password is not on the battery it is in the volatile memory.
The battery supplies the power to the volatile memory to make sure it retains its settings.
If you have removed the Cmos battery and when you put it back the machine still has a password then the password is written into the non-volatile memory and cannot be re-set that way.
Get a hold of someone with ERD Commander and they will drop the password off in a couple of minutes
Mar 30, 2009 | Dell Latitude X300 Notebook
My Dell Laptop will not power up! Dell inspiron 1000 notebook
take the cmos battery out and put in the power cable, and start the machine
Mar 26, 2009 | Dell Inspiron 1000 Notebook
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Precision 690  Motherboard Logo
207 people viewed this question
Alun Cox
