Question about Canon BJC 1000N InkJet Printer
I have canon BJC 1000 printer how can i use it with laptop
I have canon BJC 1000 printer , my laptop with vista can not install printer software, is there any way to operate the printer with the laptop which operate on vista windows?
    President:
  • 2,692 Answers
No . Each piece of hardware requires a driver for the Win OS that is compatable. This printer was manufactured to run with 8 different systems if you include Mac.The only way to use it is to either downgrade to win Xp or the force Canon to provide a driver for you model for VIsta. I do nbot see that they wouldl be inclined to do that for a out of date product.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=7952
Posted on Jan 11, 2009
  • Thomas F. Schneider Jan 11, 2009
    http://www.usa.canon.com/consumer/contro...
Is Canon BJC-1000SP printer compatible with Windows vista home premium
Hello my friend, Canon BJC-1000SP is always compatible for vista provided that you install the canon BJC-1000SP Driver for Vista Platform. All hardwares are always running on different platform provided that you need to install its driver compatible or supports the platform you are using. Coz hardwares are dependent on the softwares. If you want to test kindly download this driver BJC-1000SP this driver supports both XP and Vista Platform.
Hope this will help your problem solved. If you need more assistance just reply to this post. If you find this solution very helpful please rate this solution. Thank you
Jul 08, 2009 | Epson R245 InkJet Photo Printer
Is this printer compatible to home edition software and how to find the drivers?
according to canon the drivers for the bjc80 will support windows 95,98, and ME not xp home.
If you need more help let me know.
Mark
May 05, 2009 | Canon BJC 80 InkJet Printer
Bjc2100 install disk won't work on my laptop. I use Windows Vista system.
The BJC2100 install disk came out when Windows 98 was in its heyday. It will not work in Windows Vista. The Windows Vista OS already has a driver imbedded that will work with your BJC-2100. It "should" recognize the printer and automatically install the driver. If it doesn't, try the "Add Printer" feature, select Canon as the manufacturer, and look for the BJC-2100 Series driver.
Dec 10, 2008 | Canon Office Equipment & Supplies
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
I need an installation disk for installing the printer driver for a Canon BJC-1000 Series printer.
You can download drivers here. Use the Select OS option to see what drivers are available. If you are running Windows Vista, the drivers are part of the Vista package -- use the Add Printer option, select Canon as the manufacturer and you will see the driver for the BJC-1000.
May 05, 2008 | Office Equipment & Supplies
Bjc 85 vista driver???
Canon does not list a driver for Vista. You can see this at Cannon's web link here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6620
& why here.
http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=vistadr&fcategoryid=230&modelid=6620
There is one other way to get a driver for vista. (Maybe). Microsoft has a program that you install. It scans your PC (make sure your printer is turned on)!
It checks your PC to see if it can run Vista. (even though you have it installed).
It also will show you at the end what driver software you need for vista. Including your printer & will give you a link to download the proper driver.
You have nothing to loose.
Once the vista program has finished & you download any missing drivers, just delete the program from Add/Remove programs in your control panel. Microsoft's Vista checker program link. Windows Vista Upgrade Advisor.
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Good Luck.
Mike
Mar 25, 2008 | Canon BJC-85 InkJet Printer
DRIVERS OF PRINTER CANON BJC-250 FOR WINDOW VITA
[English Below]
No lo encontrarás.
Utiliza el mismo para Windows XP, cuando lo instales presiona "Continue Anyway" (o su equivalente en Español). Esto debe funcionar, hasta la fecha Vista aún no tiene soporte para tu modelo de Canon.
Suerte!
)O(
The question is: "I cannot find the controller for a Canon BJC-250 Printer for Windows Vista"
CoolDragon's Answer:
You won't find it.
Use the same one for Windows XP, when you install it press "continue anyway" until today, Vista has no support for that model of Canon printer.
Jan 24, 2008 | Canon BJC 250 X. Files InkJet Printer
Canon bjc 85
Vista driver for this machine comes stnadard with vista but will not work when old xp drivers are present (or were when upgraded to vista) , remove old driver from system, connect printer,  vista should auto reconise and install.
Here is a canon link explaining Vista with BJC 85
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=230&modelid=6620
Oct 31, 2007 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 1000N InkJet Printer Logo
184 people viewed this question
old marine
old marine
