Printing problems error in the cassette
Roland rs-640 error motor code 0010 0010
Posted on Dec 03, 2012
Error code - Different paper size is set. Check paper size
turn the dial on front of paper cassette to match paper size in the cassette
Mar 04, 2015 | Kyocera FS-2100DN Laser Printer - FS2100DN
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
I have a canon mx870 and it will not print from the cassette lower tray, even if it is set to it, it always wants to print from the rear, even if it is closed!
It may be that, if it's not the tray allocation settings causing the problem, some printer maintenance will fix this. I had this problem, after I had only had my MX870 a couple of months. Suddenly, it would not print from the cassette even when printing to standard A4 plain paper. Nor would it print from the cassette even when I changed the printer settings from 'automatic' tray selection to print always from the cassette. After seeing something online, I then ran some of the MX870 maintenance applications, first 'Cleaning', then 'Print Head Alignment', and finally 'Roller Cleaning' for the cassette rollers (for which you have to remove all paper from the cassette). The problem has been solved (at least for the moment).
Mar 05, 2011 | Canon PIXMA MX870 Wireless Office...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Error no paper in cassette adn there is paper in
that means that the LTR (letter) paper is empty...if there is paper in the cassette, then the problem could be an actuator, sensor, or the feed tires are bald and picking up the paper.
Dec 03, 2009 | Canon PIXMA MP610 InkJet Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mp830.can't print from cd cassette i get an error: close print door first
Make sure the driver has the correct media selected. You may have to select a "tray" to print from. This may be done using a button on the control panel, using the menu and LCD display, or by setting the software driver preferences.
If that does not solve the problem try deleting and reinstalling the driver. Don't forget to check the owners manual. It may have information on this problem
Nov 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
152 people viewed this question
jasbo
jasbo
