LG rt-z52sz60db lamp and overheat fault light
Dad's TV, worked fantastically until one day turned off,...tried to restart then displayed "lamp and overheat" warning lights on front - bottom right hand side panel....Dad replaced bulb and still not turning on and still displaying same fault lights....I think...reset??!!!!...somewhere,...have resolved to manual but still no result or answer....should be simple,...TV is immaculate condition and never moved, in aircon, cool, dust and smoke free environment.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I admit not having seen this model but if a DLP with lamp it has fans.
A common issue with sets is while house/home may be spotless the fans also intake air and ANY dust in the air.
I have seen many where the airflow inside the set gets blocked with dust on the fans and paths themselves----many when taken outside and blown clean with compressed air look like a dust storm and suddenly the set now works.
Even a moderate amount on fan blades will cause the fans to run a little slow which will trigger the overheat isssue especially on the Lamp fan which cools that part.
I know people who live in spotless homes do not like to hear this but it is rather common.
A reset if it exists for this set will NOT help this kind of issue---I see you have posted this issue in several places on the internet so consider that not all issues can be corrected with a reset and it is possible I am correct here----no major parts are required to prove or disprove this---in fact nothing to lose by trying it---as proof I offer a link to another set with a somewhat similar problem whose answer has helped several other people---I keep track:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on Dec 03, 2012
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Apr 01, 2008
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
SOURCE: lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Posted on Jan 12, 2010
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
Jun 24, 2013 | Philips Televison & Video
I just turned my digital receiver on & my LG tv & the tv says it's not programmed
Try to unplug from power both the set and the box for several minutes and then power both back up---this will allow both to try to reboot.
Dec 08, 2012 | LG 32LG30 32 in. LCD HDTV
I TURN ON THE TV & TURNS OFF AFTER A FEW SECOUNDS
Check Lamp Fan and If Lamp has never been replaced ,then you could have Bad Lamp Mats has them for $89.00 1-800-629-1118. If they do not have Lamp then Look on EBay.
Jun 19, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
I OWN MITSUBISHI MODEL WD-73C9 TV AND THE POWER ON INDICATOR LIGHT RAPIDLY FLASHES GREEN WHEN YOU TRY TO TURN IT ON. SOMETIMES THE WELCOME SCREEN WILL COME ON FOR A SECOND AND THEN THE TV SHUTS OFF OTHER...
Is there audio and is when was the last time a welcome screen came on (in other words, are you even getting that anymore)? I have the same TV but I only get the Mitsubishi Splash Screen only comes on when the TV powers off so I'm a little confused by that. Also how bad were the vents and filters when you cleaned them out and how is the ventilation behind the set? Have you checked the lamp? That's a two year-old set, now so I'm kind of leaning on you needing a new lamp. I had to have mine replaced last summer. You're supposed to get 4,000 - 6,000 hours out of them but depending on your environmental conditions, that lifespan can be dramatically reduced as dust buildup and poor ventilation will cause it to overheat the lamp and normally before it's going to go bad, the TV knows this and starts getting hinky as you described (will come on but then shut-off, etc.). In my case between the wife and three kids and the dad (me) who only gets to watch his shows on the DVR after all the kids are asleep, our set is on 8 - 11 hours a day and longer when I watch the kids at home two days a week so I easily blew through the lamp lifespan in 18 months.
You should check the lamp. Refer to your manual, but it's only two screws in the lower right of the back of the TV, Use rubber gloves as well. If it is the lamp go to Mitsubishi's website and order them. They're OEM and only $100 and cheaper than any of the after-market ones. Also Mitsubishi warranties them and if you need it immediately, you can call them to place the order and just pay an extra $50 for overnight delivery. I've had to do this my TV and my in-laws and I've been very satisfied with the Mitsubishi customer service.
Let me know how it turns out.
Apr 22, 2011 | Mitsubishi MBS73A Base for WD73C9 WD73837...
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
LG Rear Projection 44" will not turn on
Make sure you reinstall the lamp door as there is a lamp door switch that must be closed or the unit will not fire the lamp, there should be a small hole or opening on lamp door housing. Some people install the lamp without reclosing the door just to see if the unit works , just to find out if it will not work, and when it does;nt think something is wrong, they do not put the lamp door back on first. Not to say this is the case but it does happen.
Jun 12, 2009 | Samsung HCN5527W 55" Rear Projection...
I have a lg rt 52sz, lamp light flashed so i replaced the lamp, now when i turn the tv on the red light turns orange for 8 secnds then tv turns itself off, the lamp is still flashing. Signed unhappy...
make sure the lamp is in correctly and the door is also on good. there is a switch on the lamp door opening that wont let the set turn on if the door is not on.
Apr 24, 2009 | Televison & Video
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
