Question about Zanussi FJS1225W Front Load Washer
My washer wont spin and makes a humming noise
I had a similar sounding problem FJS1225W accompanied by Error code E52, I replaced the worn out motor brushes. Job done.
Posted on Dec 09, 2012
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Why my frigidaire top loader wont spin?
Hi - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 18, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
I have a whirlpool washer and it will not spin
The problem will be in the main board or the spinning coil may be short circuited, You can easily check the motor during the spinning process you will find the humming noise if you do not found any humming noise kindly replace the board
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont spin. Makes a humming noise and a burning smell
your belt needs changed. and i would check the pump to make sure its not siezed
Dec 11, 2009 | Maytag PAV2300 Top Load Washer
Wont spin
motor coupling is the problem. You have two one for the motor and one for the transmission one of these are broke.It does agitate doesn't it?
Sep 03, 2009 | GE WBSE2090A Top Load Washer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
264 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
