Harmon kardon avr 355 protect - Audio Players & Recorders
SOURCE: Harmon Kardon AVR 630
I ever had this problem, so I contact the service center and they re-program all setting. So,would you like to ask the nearest service center.
Posted on Oct 10, 2007
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
SOURCE: cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Posted on Jun 10, 2008
marsrover
  • 682 Answers
SOURCE: I have a Harmon Kardon
please check all speaker cables for short circuit in receiver side or in the speaker side itself.
Posted on Jun 25, 2008
SOURCE: was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Posted on Mar 21, 2009
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Protect mode
thank you for the advise. i have the harmon kardon avr 3600 and was worried that i destroyed it. i will take it to a shop and get it fixed since it is a great receiver.
Jan 25, 2013 | Harman Kardon AVR 3600
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
Harmon Kardon AVR300.**protect** blinks when powered on.Took cover off no obvious problem.Disconnected EVERYTHING from back panel,still blinks **PROTECT**.
The protect message means that the outputs are shorted. This is a fairly common problem that can easily be fixed by any shop that handles audio gear. Expect a parts cost in the $20-$40 range.
Dan
Mar 16, 2009 | Harman Kardon AVR 300 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
80 people viewed this question
 Grubhead
Grubhead
