Question about Lexmark X2650 All-In-One InkJet Printer
How to scan when error code EC5 is on my lexmark 2650x?
I keep getting the error code EC5 indicating a faulty cartridge. I don't want to print anything just use the scanner but it won't allow me. Any ideas how to get around this without having to buy a new cartridge...
SOURCE: Lexmark x2500 printer ink cartridge
OMG! The cartridges are so expensive. I've tried to refill the cartridge myself and it put up an error message too. The only thing i did was splurge and bought a new cartridge!! Sorry.
Posted on Jan 22, 2009
Soulvisitor
  • 1113 Answers
SOURCE: I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Posted on Nov 07, 2009
don_farr
  • 1018 Answers
SOURCE: won't print reads error code 50c
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Dec 31, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: hi my lexmark x2650 keeps
    The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
    Posted on Jun 01, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: Bought compatible cartridges for lexmark
      For the most optimal output experience with your AIO, Lexmark recommends that customers update their firmware. The firmware helps ensure that customers receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements.
      If you choose to upgrade firmware, note that unauthorized use of third-party 'cloned' cartridges will no longer be possible.
      When purchasing ink cartridges, Lexmark customers have two options:
      Regular ink cartridges without license terms (100A/100XLA) that you may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
      Return Program ink cartridges that provide customers with an up-front discount in exchange for their agreement to use the ink cartridge once and return it only to Lexmark for remanufacturing and recycling.
      Posted on Sep 01, 2011
      Lexmark X7170 will not print in grayscale
      i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
      Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
      X2600 printer has EC5 problem
      The error indicates that there is a short in one if the cartridges. Please follow the steps below to identify and fix cartridge issues:
      1. Make sure the printer is on.
      2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
      3. Remove both cartridges from the carrier.
      4. Close the printer cover.
      5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
      6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
      7. If no error appears, reinsert the other cartridge. Close the printer cover.
      8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
      Feb 07, 2012 | Lexmark X6150 All-In-One InkJet Printer
      Wont let me print
      The error code "EC5" indicates a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
      Jan 07, 2012 | Lexmark X2670 All-In-One Printer
      What's C 5 E blinking in the printer screen?
      The EC5 error code indicates that there is a short in one of your print cartridges. Please follow the steps below to identify and fix the issue:
      2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
      Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
      5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
      7. Close the printer cover and check for any errors.
      8. If no error appears, reinsert the other cartridge. Close the printer cover.
      9. Replace whichever cartridge is causing the error to appear with a new cartridge.
      Should the problem persists, please contact Lexmark Technical Support Center for additional assistance.
      Oct 10, 2011 | Lexmark X2600 InkJet Printer
      Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
      Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
      You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
      For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
      Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
      Hi my lexmark x2650 keeps flashing error code ec5, how do i correct this?
      May 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
      I just replaced my ink cartiges and now it's flashes E C 5
      Hello. You can check the error codes that Lexmark printers show on this web page . . . . .
      http://support.lexmark.com/index?page=content&id=SO4438&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1275158659149
      If your inks are new, just take the cartridge back to the supplier as sometimes a new one can be defective slightly.
      Most likely though, the error can be got around by taking the cartridge back out, and finding its copper contacts panel, and very very gently cleaning that with something suitable. Make sure that you DO NOT get any cleaning fluid on the actual print nozzles as this will cause chaos when printing later.
      I use foam cleaner, or SERVICOL spray to clean such things when working on them.
      I hope that helps.
      May 14, 2011 | Lexmark X2670 All-In-One Printer
      Printer wont print showing C 5 E on display
      EC5 error code indicates a short has been detected in one of your cartridges. Try to remove both your cartridges from the printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any error. If none, open the cover and reinsert the other cartridge. Close the cover and check for any error. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
      May 04, 2011 | Lexmark X2670 All-In-One Printer
      Won't print reads error code 50c
      Don
      Dec 31, 2009 | Lexmark X6150 All-In-One InkJet Printer
      Problem with cartriges
      EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
      Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
      Mar 02, 2009 | Lexmark X2600 InkJet Printer
      Lexmark X2650 All-In-One InkJet Printer Logo
      43 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
