Question about Texas Instruments TI-30XA Calculator
My screen i s completely blank and will not turn on when i press on. i need help ASAP!
  • kghaniezadeh Jan 27, 2009
    when i press the on button it dosent turn on it has been working for 2 years but all of a sudden it stoped working help
  • 55 Answers
Check to make sure the battery is installed correctly or get a fresh battery and install it.
Posted on Jan 12, 2009
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
PS3 Input Problem Please Help
Turn off your PS3 and then hold the power button down for 10 seconds. You should hear two beeps and the PS3's resolution should be set back to the default.
Jul 13, 2009 | Sony PlayStation® 3 (80GB) Console
Screen goes completly blank what ever I am using on my PC. Have to press windows key and retrieve minimizes page to view. Any ideas please
see power settings in control panel.
It must be set on blank screen after 20 mins or something like that.
set it like this
turn off hard disk- never
blanks screen - never
set never with everything
cheers
Jun 22, 2009 | Dell Studio 1737 Laptop
Blank Screen
you will need to have the LCD change
Aug 26, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 6230i my screen keeps going blank
remove MMC from ur mobile,then switch on ur mobile then press restore key that is *#7370# after inserting this u have to enter 12345 as factory code, then it will start
Jun 16, 2008 | Nokia 6230i Cellular Phone
Tom Tom One
Is this a TomTom One 3rd Edition? If it is and if the blank screen that is coming up is completely white, a fix has been posted at http://www.tomtom.com/support/index.php?FID=8578&Lid=4
Before you install the update, be sure that you have the model and problem described. I hope this helps.
Dec 27, 2007 | GPS
Blank Screen
If it is under warranty return it asap or report the problem...
http://www.tomtom.com/support/index.php?Lid=1
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Sound but blank white screen
Hello, please contact your Philips Dealer ASAP. If you need more info please advice. Best regards, Arpi
Apr 19, 2007 | Philips 15MF605T 15 in. LCD Television
Texas Instruments TI-30XA Calculator Logo
96 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
