Acer aspire m1202 will not boot but fans run - Computers & Internet
  • 7,627 Answers
Remove all media, DVDs, CDs, USBs, unplug from AC, remove battery, leave battery out, plug into AC, reboot. If that fails, Do a system restore/recovery. Do you have a repair disk? You didn't supply your OS? If that fails, remove HDD, test, replace is necessary.
Posted on Dec 03, 2012
  • 44 Answers
SOURCE: Acer Aspire 1804WSMi - will
I think your memory is loose or damaged. Try cleaning it with an eraser and brush it with a clean paint brush then reinstall it in your PC. Test run it.
Posted on Aug 26, 2008
jo_chinmay
  • 142 Answers
SOURCE: acer aspire sudden death my
Dear sir
if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
simple.. if u need more help please contact feel free.. thianks..
Posted on Dec 15, 2008
joecoolvette
  • 5660 Answers
SOURCE: Acer Aspire desktop AST135 cooling fan runs fast & slow - noisey
If the computer case, or Processor fan is noisy, it is due to the bearings are bad. The bearings are worn, and this allows the fan hub beneath the fan blades, to rub.
(If you gently rock the fan by lifting up on one side, and there is a perceptible amount of play, the bearings are bad)
Suggest you replace it.
For a case fan, just measure the dimensions of the fan's outside case.
Measure the Height and Length, plus the Width, (Thickness).
Look at the connector on the end of the fan's cable.
Most fan sizes are shown in Millimeters. (mm) If you are not familiar with the metric system, you can go online, and use a free Millimeters to Inches Converter.
Examples:
1) 80mm = 3.14960 inches. Slightly over 3- 1/8th inches
2) 92mm = 3.62204 inches. Slightly under 3- 5/8ths inches
3) 120mm = 4.72440 inches. Slightly under 4- 3/4ths inches
4) 130mm = 5.11811 inches. Slightly under 5- 1/8th inches
See if it is a 2 pin connector, 3 pin connector, or 4 pin connector, on the end of the fan's cable.
(Fans operate on DC electricity. Just like the rest of the computer. DC is a Positive connection, and a Negative connection.
For a connector with 2 pins, that is all that is hooked up. Just power to the fan.
For a connector with 3 pins, the third pin is for the computer, to show what RPM's the fan is spinning at. {Revolutions per Minute}
For a connector with 4 pins, the fourth pin is a sensor connection.
The computer will speed up, or slow down the fan, according to what RPM is needed)
For a Processor fan the connection should be matched also.
When looking for a replacement Processor fan, it is the processor socket that the processor sits in, that you should look for.
You didn't state the full Model Number, such as AST135-US3104, or AST135-US3303, (It's on the back of the computer next to the Windows Product Key)
The two above models have an AMD Sempron processor.
They use a Socket 754.
(AMD Sempron 3100+, and AMD Sempron 3300+.
The AMD Sempron 3000+ that operates at 1.8Ghz, could be a Palermo Core that uses a Socket 754, or the model that uses a Socket 939)
Need help in finding a replacement computer case fan, or Processor fan? State so in an additional comment.
Posted on Jan 18, 2010
  • 10 Answers
SOURCE: Acer Aspire X1301 is excessively loud, runs one speed always.
Are all the vents clear from obstructions, fluff etc?
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
Can't connect my aspire m1202 to internet
I need more information to assist you.
Do you connect to the Internet using a LAN cacle to a modem and or router?
Do you have a wireless router, what is the make and model.?
Do you have an Internet service provider.
What error messages do you get.
Mar 30, 2012 | Acer Computers & Internet
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
Acer aspire m1202. turns on but no bio view just runs the fans and there isnt any sort of beep code either. just runs and runs nothing happens. oh and you cant turn it off via power button you gotta unplug...
t f doesn't open
* remove the fan/blower n the processor and check if there's still a heat sink paste on it. (most part of center metal attach),then clean the sorroundings of the process...this s due to an overheat that's why the blower or fan might sometimes stuck up at the pc stop working.
* detach each memory and try to clean the slots and put it back properly.
* check the power supply,might getting open voltage and needs replacement.
hope t helps...
Jun 06, 2011 | Computers & Internet
I have an Acer M1202 that I performed a Windows flash upgrade. For whatever reason it did not complete i guess. The window closed and I tried to reflash it but it would work. When i rebooted the system...
yes there is , **** its not what you sould do.....u should try to flash again using a floppy drive in dos.
if u dont know how to do that, google for it, its not wise to flash in windows ;)
Apr 30, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Replace the Vista Home Premium with XP on ASPIRE M1202
Your best option is to upgrade to Windows 7. It is free for (I believe all) Vista users, and you can run programs in XP compatibility mode.
Dec 04, 2009 | Acer Computers & Internet
We are getting a No Signal on our monitor,
it should be motherboard problem.
try to check it nearby service centers
are you able to hear any beep sounds
pp
Nov 21, 2009 | Acer Aspire L100 PC Desktop
No booting / No Display But fan is running
CHECK YOUR SYSTEM RAM IF IT IS OK THEN THERE IS A PROBLEM WITH THE MOTHERBOARD
Jul 08, 2009 | Acer Aspire 4730-4947 Notebook
My acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
Mar 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Laptop is not working
If your computer no boot, respond to a motherboard failure, (video, memory, hard drive) - Try to boot with a boot CD and see what happen.
Sep 24, 2008 | Acer Aspire 1800 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
