When open ucam at starting of application
If you need to remove youcam from start up do the below steps correctly.
1. click on start menu
2. click on run
3. in that window, type "msconfig" without inverted comas
4. continue with the prompt
5. in the system configuration utility, select" startup"
6. untick youcam/cyberlink software
7. click apply and ok
8. restart the system.
Hope this helps
SOURCE: hi my lenovo laptop Y460
Side by Side architecture uses a trick in a file called a 'manifest' to call a special system file instead of the regular Vista system file (a .dll). The error is saying that finding that special dll written for that application is not working somehow. (side-by-side configuration is incorrect)
If you recently installed new software, like AVG Virus protection, remove it. If not, try to do a system restore (found in Start - Programs - Accessories - System Tools) back to a time when you know the system was working properly. This will not affect your data, but may uninstall software or updates installed after the restore date you choose.
If this does not work, you need to be prepared for the long version of this fix as it is very technical and very long. Let me know if you need more help solving this problem
