Question about Philips PM-DVR8 Remote Control
Magnavox converter box and tv preset channel
I set up the box for my mother and it worked great. She accidently changed the channel on the tv from 3 to 13, now she can't set it back. I live out of state and don't have a manual. She has no picture/snow...what does she need to do?
Ann
    Sergeant:
  • 227 Answers
Have her take the remote and hit 03. Alot of people think hitting the 3 only will work. Not the case have to hit 0 then 3.
Posted on Jan 11, 2009
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
I have installed a converter box we have a rooftop antenna, now I cannot record, it does not seem to find channel 9.1, 12.1 etc only 9, 12 etc I went from antenna to converter to DVD MWR10D6 to TV. My tv...
If you have the converter connected to the recorder by composite or s-video(line inputs), you will need to specify which jacks from within the setup menu of the recorder. There are 2 sets of line inputs into the recorder, so you have to select the right ones. They are called L-1 and L-2. The L-1 jacks are in the rear and the L-2 jacks are in the front. The channel selection should also be on L-1 or L-2. If you are using the
RF input(fat cable) to the recorder, you should have the recorder on the channel number that matches the output of the converter (channel 3 or 4). The converter RF output is selected by a switch in back of the converter or by the setup menu of the converter.
Menu path for setting L-1 or L-2 inputs:
Setup > General Setting > Video > Video Input > L-1 or L-2 > Video In or S-Video In
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Converter box connection
You need to get a 75-ohm to 300-ohm transformer, also called a "balun". Radio Shack sells them and you may also be able to find them at retailers who sell TV antennas. It's a small cylinder with a threaded connector at one end for the cable from the converter, and a flat wire with two terminals for the TV connection. Connect the terminals under the "VHF" screws on the TV, put the set on channel 3 or 4 depending on your converter box setting (most are on 3 out of the box) and you're good to go. On a set of that age, you might need to tinker with the fine tuning adjustment a little for the best picture from the converter box.
May 04, 2009 | Insignia Digital-to-Analog Converter for...
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
TB100MW9 DTV DIGITAL TO ANALOG CONVERTER
I assume you are attempting to connect another device to the set.
Selection of the output channel is normally accomplished from the external device, not the set.
Jun 30, 2008 | Philips Magnavox 27MS343S 27" TV
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Philips PM-DVR8 Remote Control Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
