Question about Sony Handycam CCD-TRV87 Camcorder
CCD-TRV87 won't turn off
When switched to OFF/Charge, camera stays on.
I have CCD-TRV57E and found camera would switch itself ON and could not turn off. Had switch replaced some years ago and is now fine. Also have a friend with same camera and had the same problem, also had switch replaced.
Posted on Dec 03, 2012
5 Suggested Answers
cpt100
  • 154 Answers
SOURCE: Moisture sensor on sony ccd-trv87
Moisture sensor is on the main circuit board and to replace the sensor you probably invest $100-200 for repair. It's the sensor or component surounding the sensor which gone bad. No other way around it. Good luck.
Posted on Mar 14, 2007
  • 21 Answers
SOURCE: camcorder
hi bagirl.. yes of course if they use the exact same type of cassatte for recording . in other words u can take the casatte from 1 camera and play it on any camera in the world if they use the same type of cassatte.. if they use hard disk then the answer would be no...
pls rate..
Posted on Jun 04, 2008
  • 76 Answers
SOURCE: how to add the Sony
This camcorder as far as I remember has not got a fire wire out connection however on the left side as you look at the lens there are various video and audio output connectors such as YC commonly known as SVHS.
To hook the camcorder up to a computer you need a box known as a break out box.
Basic it's a box that take the analogue video and audio signals into it and converts them to a digital signal.
The out put connector from the box is fire wire which will connect to a computer with a fire wire port.
Most modern laptops have a fire wire input in fact it's been around for a good 10 years.
There are many break out boxes on the market ranging from £70 to several hundred £ss.
I have a. ADVC300 the write up from the net is as followes.
ADVC300 is the ultimate bi-directional analogue to digital video converter unit for the video enthusiast. Featuring high-quality image enhancement technology including digital noise reduction and image stabilization using Line Time Base Correction(LTBC), ADVC300 instantly cleans, stabilizes and preserves old VHS and Hi8 videos in clean DV format. Supporting Windows and Mac OS, ADVC300 is compatible with all widely used video editing applications including Canopus EDIUS, Final Cut Pro, Avid Xpress DV and Adobe Premiere Pro.
This costs £382 from but you can get cheaper.
Posted on Sep 13, 2010
  • 304 Answers
SOURCE: my camera wont charge in the tray or the charge
My guess is that with the age of the battery it isn't able to hold a charge anymore which means you'll need to purchase a new battery. Your best bet for that will be to go through Sony or the website Dr. Battery.
Posted on May 11, 2011
Can tapes from a Digital 8 camcorder play on a Hi8 xr ccdtrv87?
No, CCD-TRV87 is analog camcorder that can not playback digital format video-8 tapes.
Jun 23, 2010 | Sony Handycam CCD-TRV87 Camcorder
Sony trv87
Although the battery shows it takes a charge and the camera will run in playbackmode (VTR) I found if I remove the battery and run on AC the camera turns on and now I can record with it. The battery must be the problem.
Jan 25, 2009 | Sony Handycam CCD-TRV87 Camcorder
Camcorder
pls rate..
Jun 04, 2008 | Sony Handycam CCD-TRV87 Camcorder
Use as a capture camera
try attaching the AC adapter. Also, go into the menu settings, and make sure that the auto power off setting is turned off.
Feb 05, 2008 | Sony Handycam CCD-TRV87 Camcorder
Sony HandyCam CCD TRV 46E
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 23, 2008 | Sony Handycam CCD-TRV87 Camcorder
Zoom is stuck
fix here alamocameraservice.com
Nov 29, 2007 | Sony Handycam CCD-TRV87 Camcorder
Mar 14, 2007 | Sony Handycam CCD-TRV87 Camcorder
Won't turn off
the On/Off/VTR Switch doesn't function anymore and the camera is a month old. Basically anytime the battery is in the camera or the camera is plugged in, it remains 'On'.
That means you can't charge batteries or use VTR mode, or turn the thing off. Way to go on this one Sony.
Oct 12, 2006 | Sony Handycam CCD-TRV87 Camcorder
Open Questions:
See all Sony Handycam CCD-TRV87 Camcorder Questions
Sony Handycam CCD-TRV87 Camcorder Logo
171 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
