Question about Car Audio & Video
I have a pioneer xc -L5 with 3 units cd/radio and mimidisc how can i connect it up for the minidisc to work ! currently shows no audio when both rear cables are connected ! and will not come up on dis
Only 3 UNITS missing the cassette player unit !
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: new pioneer deh-p4800mp doesn't work
How about the red (switched power) wire? The unit will not turn on unless you have 11+ volts on the yellow AND the red power leads.
Posted on Mar 15, 2007
  • 5 Answers
SOURCE: Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Posted on Mar 25, 2009
josetejas
  • 300 Answers
SOURCE: Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Posted on Jan 19, 2010
SOURCE: Pioneer KEH-P4830R connection to AUX source
To use the AUX function on the Pioneer KEH-P4830R, you first have to enable the AUX function.
Turn the unit off (by pressing down source I think). Then once the unit is turned off. Hold down the 'source' button until a new display comes up, then cycle through to you to to the AUX function, and select ON. Finish by holding down the 'source' button again. Now turn the unit back on by tapping 'source' button, and you will now have the option to choose radio, tape or AUX from the source menu
Posted on Jun 07, 2012
My pioneer deck wont turn on after I turned the bass up.
you may have blown a fuse open it up carefully with the unit unplugged and look at the fuses and see if any are discolored or look broken.
Sep 19, 2013 | Pioneer Deh150mp Cd/Mp3 Car Receiver...
How can i acsess the pioneer mj-15 to play long play minidiscs currently says no audio!
The unit can be repaired by the right people- there are not so many of them around. Discs can not be repaired!. Also the model you have may not be compatible with other disc formats that were made at a later time. This disc systems use higher compression and different algorithms.
I have worked on more of my share of these units but mostly Sony and Tascam units. Sony invented the thing.
Jan 11, 2013 | Pioneer MJ-L5 Mini Disc Player
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
Can I hook up my Ipod to this sterio, A deh-1800
This radio has no IP-Bus (Pioneer's peripheral plug in) plug on the back of the unit or any connection for USB or 1/8" stereo headphone jack on it. You will not be able to conect an iPod to this unit. Visit the website at www.pioneerelectronics.com to see their current iPod solutions. They have multiple head units that allow for you to charge iPod and iPhones as well and give you control through the head unit or through the iPod itself.
Jun 20, 2009 | Pioneer DEH-1800 CD Player
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
Input/cut out
With the first question, if you are using an ip-bus to RCA adapter to connect your iPod to the CD changer port on the back of the radio, it won't be recognized until you turn on the AUX function on the radio. In the main function menu (usually gotten to when the radio is powered off), there is an option to turn on AUX1 or AUX2. Do this (consult owner's manual) and you should get your audio to play through.
With the 2nd question, the errors may have something to do with the file format on the discs. Not sure though.
Aug 01, 2008 | Pioneer MEH-P5000 MiniDisc Player
Power has to reset with each restart
It sounds as though you may have the constant and switched power connections reversed. The yellow wire from the Pioneer head unit has to be connected to a constant power source, and the red wire has to be connected to a key-switched power source. Assuming that both are currently connected to different wires, try reversing them and see if that solves the problem. Otherwise you'll need to get a voltmeter and test the factory wires for voltage.
Jun 27, 2007 | Pioneer DEH-2700 CD Player
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
