Question about Kitchen Ranges
One gas burner in whirlpool gas stove top will not light when turned on. Has to be lit manual
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
The electrode on that particular burner has eroded or is dirty enough from boiled over items that it cant spark to ground anymore,you can try filing the electrode off carefully with a fine nail board to see if its just dirt or its actually defective
Posted on Dec 03, 2012
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
  • 172 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
SOURCE: gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Posted on Dec 14, 2008
SOURCE: Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Whirlpool gas stove
Replace the regulator on the gas line.
Jan 01, 2009 | Whirlpool SF325 Gas Kitchen Range
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Stove top pilot light
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
