Question about Craftsman Heavy Machinery
Sharpen flail chipper blades
Can ya sharpen the flail knifes
wadembly
  • 462 Answers
SOURCE: metalic clanging
no its not you might have something cought in the safety gaurd check & clean if it still happens then somethings really loose inside check & replace if needed
Posted on Jun 05, 2009
vincob
  • 718 Answers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Posted on Oct 09, 2009
rwvanlue
  • 486 Answers
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
Posted on Nov 08, 2009
bbreton
  • 437 Answers
SOURCE: replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Posted on Jan 23, 2010
Testimonial: "I have the casing off,and have penitrating oil on the pins and screws ----- tomorrow is an other day!"
dogsled48195
  • 411 Answers
SOURCE: I have the small electric chipper shredder and
In your browser type in http://www.mtdparts.com/webapp/wcs/stores/servlet/Home_10101_19502_-1?cm_mmc=MSN-_-MTD-_-Yard%20Machines%20Parts-_-Sponsored
Posted on Feb 25, 2011
Testimonial: "THANKS"
Sharping the blades
I dont think you need to remove the fly wheel to sharpen blades. Remove the housing an the blades are visible an removed that way. Not a hard job at all.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
How to sharpen the blades on my Swiss army knife?
You can sharpen your Swiss Army Knife is using a circular motion. Start by holding the blade away from you at the proper angle. Run the blade of your Swiss Army Knife in a clockwise motion on the stone until you have sharpened that side of the blade. Turn the blade over and repeat with a counter clockwise motion.
Jul 09, 2012 | Camping, Backpacking & Hiking
Sharpening blades on a troy bilt super tomahawk chipper shredder
the chipping blade use a knife sharpening hone the shredder side you can flip some over
Dec 11, 2011 | Garden
Replace flails on 5.5 Yard Machine
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a craftsman chipper / shredder and it doesn't do a very good job - is there a piece to change or a blade to sharpen?
Nov 24, 2009 | Troy-Bilt Chipper Shredder
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Apr 29, 2009 | Garden
I don't have a manual for the tomahawk chipper and I cannot figure out how to change the blades.
You will need to turn the flails (also called cylinder hammers).  Each flail has  4 sharp corner cutouts, only one of which is in use.  When you turn them you get to use a fresh corner, the dull one is still there but no longer contacts the stuff you are chipping.  You will need to remove the chute to access the flywheel, and by rotating the flywheel access the steel bars (cylinder pins) that hold the flails and spacers.  I lay the chipper down, with a 5 gallon bucket protecting the engine, gas tank, to access the bottom, so that you can, using a punch, drive out the 3/16X3/4 roll pin which can be found in one of the long spacers.  You will note each bar has 4 flails, with two long spacers and two short spacers and the roll pin goes through one of the long spacers.  You buy the roll pin punch at a hardware store.   There are four sets of bars with spacers and flails, so four roll pins.  You will want four fresh roll pins also, because the old ones are compressed and shouldn't be used again.  When you have punched out the roll pin you can then drive the bar from the end (where the chute was) but be sure to line the other end of the bar up with the hole on the other sidewall of the chipping compartment.   When you are trying to punch out the roll pin it helps to stabilize the fly wheel--I use a couple of vise grips in a way that the fly wheel is stable.  When you are pounding out the bar (called a cylinder pin) you will need a slightly lesser diameter long (6-8") bolt as a driver.  You can pound on it and it will follow the cylinder pin as it gets pushed out the other side.   When the spacers and flails fall out onto the floor, then you can turn the flails to use a fresh cutting corner and put the spacers and flails back on.  I find it helpful to file the rough edges of the inside ends of the spacers so they slide easily on the cylinder pins.  Get a round file for this purpose.  Also, keep some WD 40 on hand because these things tend to be stuck.  I do only one cylinder pin (with its four flails and four spacers) at a time, so I correctly put it all back in the right order.   You will see that the the order alternates.)
Mar 20, 2009 | Troy-Bilt Heavy Machinery
Chipper Maintenance
Maintenance (excluding the power plant) Your primary maintenance concern with chippers and shredders is their knives. You can re-sharpen chipper knives, whereas you can reverse shredder flail-type knives when dull but you can not re-sharpen them. You must sharpen chipper knives with special sharpening equipment because they are made of high-carbon steel. Maintaining sharp knives can lengthen their life and the life of the machine by keeping power requirements low. An over-dulled or chipped chipper knife will need extensive sharpening, which will remove a large portion of the blade. This obviously will shorten its life. As soon as a blade is slightly dull, you should sharpen it to minimize the amount of blade-material that you remove. All knives need sharpening at the same time to keep them in balance-even if only one is worn or chipped. Also, you must use matched sets to keep the knife the same distance from the anvil for proper chipping and feeding. After removing the knives, clean the area where they are fastened with a wire brush to make sure they will align correctly. Be sure to torque the knife bolts to their proper specifications. You will need to examine the anvil and be sure it maintains a good, square edge. Occasionally, you may need to remove and sharpen it.
Aug 27, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Heavy Machinery Logo
192 people viewed this question
Top Craftsman Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Tom Chichester
ray gallant
Are you a Craftsman Heavy Machinery Expert? Answer questions, earn points and help others
