Question about Vacuums
Vax steam mop detergent not working - Vacuums
satch498
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
SOURCE: My steam mop does not make steam.
how do you get a shark steam cleaner unclogged?
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: shark steam mop does not create steam. 7 mos old
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
a
Posted on Sep 26, 2010
heatman101
  • 43501 Answers
SOURCE: shark steam mop is leaking
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Posted on Dec 24, 2010
heatman101
  • 43501 Answers
SOURCE: Shark Steam Mop: Won't steam
heatman101
Posted on Mar 05, 2011
Where do I add detergent to my vax VRS29M powermax 10 in 1 steam cleaner
usually in the water before adding that to the tank .
Feb 27, 2015 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
I have a vax steam mop it was working perfectly
possibly not heating if you have water and no heat it could be a problem with the heating cycle that allows the steam to work .
You need a technician to have a closer look at it. It could be something small like a wire off or it could be major like an element problem. Take it in & ask for a quote on getting your machine working again.
Sep 01, 2014 | Vacuums
My VAX steam mop cleaner i bought in July is dripping water from the reservoir,what do i do, i have proof of purchase?
have u used any chemicals that not recommended in the user guide?
check for seals. some chemicals could damage water seals. those are not covered under warranty. but better to talk to warranty provider.
Aug 21, 2014 | Vacuums
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
Detergent will not spray out
It must be blocked by minerals use CLR repeat process if needed leave it plugged in
Mar 09, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vax steam mop pro
maybe if you set fire to it, you would get more steam.
May 13, 2013 | Vacuums
Vacuums Logo
189 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
