Question about Air Hogs Glow In Dark Havoc Stinger Rc Helicopter
My air hogs havoc stinger will not fly,lost instructions
It continues to spin left and flips
  • 2 more comments
  • jlauer Jan 18, 2009
    I am having the same issue. Trimming does not seem to help.
  • hopenotjunk Feb 16, 2009
    I have the same problem and no instructions. Toy was opened once . played once and sat for almost two months while trying to be fixed.
  • nina_robinso Mar 13, 2009
    me too
  • Myles White
    Myles White Oct 10, 2013
    I do not know if your version has this but on some models there is a trim dial on the side. The trim is responsible for the vertical axis of the blades (Or in laymans terms the alignment, Think of you car, if the alignment is off your vehicle pulls to the left or right) If the trim is not djuste properly the Unit will not rise into the air properly. Hope yours has this feature as then its a simple fix. Good luck.
  • 3 Answers
This might help:
http://www.spinmaster.com/files/instructions/AH%20Havoc%20Heli%20IS%20R1.pdf
Posted on Jan 10, 2011
    New Friend:
    Problem Solver:
  • 8 Answers
On some models a trim dial is provided on the remote, usually on the side. If it does then you are in luck. The trim adjusts the vertical axis of the blades (Think of it like the alignment in your car, If its off then your vehicle will pull left or right( Sounds like this could be your problem). Good luck.
Posted on Oct 10, 2013
My air hogs stinger since day one will not fly straight up.
Look for a trim setting or reference trim the users manual. It is usually a dial on the side of the remote.
Oct 10, 2012 | Air Hogs Glow In Dark Havoc Stinger Rc ...
I need a new blade were can I find one
Amazon.com seems to have quite a large selection of "replacement blades" but you will need to look them over to see if one fits your exact needs. Good luck!
Dec 31, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
Air hog havoc goes up and down just fine, no steering control
The steering control only makes the copter rotate.
But if the heli is properly balanced a right turn should get you some forward motion. A left turn should just make it spin back to the left.
Adding weight to the front of the copter will give it continuous forward motion. Then you will lose the ability to hover.
If you visit the Air Hogs website (www.airhogs.com), select "need help" and then Havoc Heli, then crash course, the video will show you how it works.
I also find that climbing makes the heli spin left and descending makes it spin right. So full right for initial startup, then a little right when climbing, and a little left when descending helps to smooth things out.
Keep in mind that this is a very small and cheap helicopter. It took me a while to get used to flying in circles to the right but with practice I have been able to get it to go somewhat where I want it to. I can take off and land from the coffee table without crashing.
Jan 15, 2010 | Air Hogs Havoc Heli Helicopters
My stinger keeps spinning
Check for crud wrapped around the tail rotor shaft
Jan 01, 2010 | Air Hogs Glow In Dark Havoc Stinger Rc ...
My helicopter spins to the left
theres trim on the remote just hit the r until it stops spinning to the left and it it spins the right then hit the l
Jan 07, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Air Hogs Glow In Dark Havoc Stinger Rc  Helicopter Logo
1,025 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
