Can the branded barstool become most rated one?
Where can i buy 2 29" avery barstool dark brown espresso
We are produce modern metal bar stool in china. If you need, please feel free to write email at mobi@herofurniture.net for further information, thank you.
Oct 15, 2013 | Target Home Barstool: 29" Avery Bar Stool...
Bamboo barstools not sturdy
that's the quality problem, or you should put it on a flat surface
Jan 03, 2013 | Buffalo Tools BABBS2 Babbs2 2Pc Bamboo Bar...
Hydralic bar stool won't go up or down
We have the same model with the picture. It's better to change a new gas lift one.
Oct 18, 2012 | Lumisource Black Ripple Hydraulic Barstool...
I need to furnish my bar and want some suggestions as to what kind of bar stools I should get.
So, it's difficult to give you too many suggestions solely because I haven't seen your bar; however as a fellow bar owner, I highly recommend the use of swivel bar stools. These stools are excellent for high traffic areas. They also make it easier for your customers to be mobile.
Jul 24, 2012 | Furniture
What is a scoop barstool?
A scoop barstool is a barstool that is not your conventionalflat bottomed stool. Regular barstoolsare normally made out of wood. Scoopbarstools are generally made of fiberglass and are backless. They are called "scoop" because there is anindentation in the seat to make it more comfortable to sit on. The seat, itself, sort of looks like anice-cream scoop. They also tend toswivel as opposed to being stationary like most barstools.
May 29, 2012 | Furniture
My bar stool has a very hard seat. How can I make it softer?
There are a few possible solutions to your problem thatdepend on the type of chair you have. Ifyou have a wooden or metal barstool with no fabric over the seat, I recommendeither placing a removable cushion there, or attaching one permanently withstrong glue. If your barstool is alreadycovered with fabric, the fabric is probably stretched and attached to the undersideof the seat with strong staples. Take astandard staple remover and pull out the staples. Then, insert any kind of soft fabric likecotton for example. Next, fold theexcess material back under the seat and attach it with staple gun staples. Make sure the staples are not reaching throughthe material because they could poke someone.
How do i Gain a BRAND EXPERTISE?
To become a brand expert on Fixya, you need to answer questions related to the brand you would like to be an expert in.
For each answer you will earn a point for that brand. After 100 points you will become a brand expert. In addition 300 points and you can become a category expert. You can view your progress by signing in and checking the dashboard on the right side of the page.
For more info on the dashboard, check out:
http://blog.fixya.com/information-and-tips/fixya-features/fixya-features-the-fixya-dashboard/
Hope that helps!
Jan 05, 2011 | FixYa Service
Platinum Legend pool cleaner get stuck behind my bar stools in my pool.
Unfortunately, this is a construction issue and not something that will be easily corrected with the pool cleaner.
Depending on the location of the port for the cleaner, you might consider shortening the hose so that the cleaner cannot make it to the barstools, but if you are like most homeowners, the barstools were built at a point in the pool that if your shorten the hose, the cleaner will not reach the rest of the pool.
To be honest, we run into this a lot and had your builder made a few alterations, this would not have become an issue.
At this point the only "true" solutions are as follows: #1) Find something that can anchor to the floor of the pool that keeps the cleaner from having access behind the table pedastal(s). #2) Discontinue using the cleaner #3) Remove the table
None of these are "great" suggestions and are probably not feasible, so option #4: live with it!
Thank you for submitting your question. Sorry we do not have a better alternative solution!
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 15, 2010 | Pentair White/Gray Legend Platinum...
27 people viewed this question
 Grubhead
Grubhead
