How do I get my wireless from one end of thr house to the other
I have Verizon wifi set up in my office, but it is on one end of the house. can I sync , a second wifi router to carry further
  • 7,733 Answers
Yes with a wifi router extender like http://www.netgear.com/home/products/wireless-range-extenders/
Posted on Dec 06, 2012
5 Suggested Answers
kakee
  • 1269 Answers
SOURCE: connecting 2 wireless routers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Posted on Oct 14, 2008
  • 31 Answers
SOURCE: Intermittent/non-existant connection with LinkSys WRT54G router
I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
Sincerely,
cdixon18
The ManInsideTheMachine
Posted on May 19, 2009
marked
  • 6487 Answers
SOURCE: my wnr3500 router will not detect my usb760 modem
Yes you can there are some wireless router now that will work with it, you can check one from Linksys and Belkin also has one..
Posted on Aug 10, 2009
  • 17 Answers
SOURCE: flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Posted on Oct 28, 2009
How can I make settings to support DHCP IP assignments and also recognize my manual IP's assigned to the LAN connected devices?
The easiest way I can think of is to shrink the DHCP address pool.
To do that, at least on the model of Actiontec router I have, click on "Network (Home/Office)" the go to the "IP Address Distribution" section of the screen. "DHCP Server" should already be selected, and under that, you'll find "Start IP addresses" and "End IP addresses." Usually, the start will be 192.168.1.2 and the end will be 192.168.1.254. What I usually do is change the start address to 192.168.1.200. That leaves over 50 addresses for normal wireless connections, and I'll general assign IP addresses from the rest of the range as follows:
192.168.1.2 to 192.168.1.9: routers, APs, etc.
192.168.1.50 to 192.168.1.59: printers
192.168.1.100 to 192.168.1.109 for other static devices. (I often find that Blu-Ray players, cable boxes, etc. behave better if they have a static address.)
But really, on home network, I doubt you'll have more than 15 devices that need static addresses, so you could set the DHCP start address as low as 192.168.1.16 if you wanted to.
Sep 17, 2015 | Linksys Computers & Internet
Please help me i cant get on the internet on my hand set ???
DO YOU WANT TO CONTACT INTERNET THROUGH WIFI OR GPRS?
ANY WAY IN BOTH FOLLOW THE BELOW INSTRUCTION:
MENUE - ALL SETTING - WIRELESS CONTROL
1- AFTER INTERANCE YOU MUST TAP ON " DATA CONNECTION " FOR GPRS ON.
OFCOURCE THIS RELATETED TO YOUR NETWORK PERMISSION.
2- FOR WIFI YOU CAN TAP ON " WIFI " STCTION . IN THIS CASE YOUR PHON TRYING TO
SEARCH YOUR " WIFI " WHICH YOU USE IT IN THE NAME OF WIRELESS ON YOUR PC
AFTER FOUND , TAP ON YOUR OWN WIRELESS WHICH SHOWN WITH SOME OTHER
WIFI WHICH IS IN RANGE.... OK AFTER TAP ON YOUR OWN WIFI , THE PHONE REQUEST
YOU TO INTER THR PASSWORD " THE SAME PASSWORD WHICH YOU INTER IN YOUR
WIRELESS OF YOUR PC . AND ASK YOU TO CONFIRM IT AGAIN .
BE CAREFUL TO MENTION THE PASSWORD SAME .
THEN THE ABOVE OF YOUR PHONE SHOWN MARK OF WIFI ACTIVITY .
NOW YOU CAN REFER TO YOUR BROWSER AND USE OF INTERNET .
GOOD LUCK
gorbesia
Aug 28, 2011 | HTC Wildfire Cell Phone
I have a netgear wndr3400 wifi route in use. It is located in my office at home. It is upstairs in the front of the house. My laptop is downstairs in the rear of the house. The system works but does drop...
WNDR3400 is a dual band WiFi router.
In case your Laptop has Wireless N card then you can can use Wireless N on WiFi else you need to use Wireless G.To enhance the Router performance Disable one WiFi Network on your Router(Either N or G) and configure Channel 11 for long range signals.
To configure said changed you need to login into Router (http://192.168.1.1 or http://10.0.0.1)Check IP address to find your router's IP address (Gateway address is the router address)Type User name and passwordDefault username and password for netgear routersUsername : admin Password : password
Goto wireless settings and disable one of the wireless network a per your requirements (N 0r G, if you have Wireless G adapter on your laptop then suggest you not to use Wireless N)Changed Channel - 11
Save settingsAnd reboot Router
Hope this helps
Jul 12, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Intermittently lose internet connection with my Westell 7500 DSL Router. Power, E4 Port, Wireless and DSL LEDs stay on but the internet LED goes out. Verizon has replaced the router but the problem...
hi,
I used to work for verizon for two years as level 3 support,here is the thing,if verizon already replaced the modem,that means that its not really the modem,its the connection,thats what we call intermittent route,here is what you are going to do,contact verizon,have them run an intermittent connection line test,tell them that internet connection is not consistent,they will create an active ticket for you,it will be forwarded to the central office and the central office will run a different test,thats what we call a test assist...they will be able to verify if the problem is the line form the central office going to your house...
thanks and God Bless
Jun 24, 2009 | Westell Wirespeed VersaLink...
Nonexistant customer service by Actiontec
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
Mar 27, 2009 | Actiontec GT704WG Wireless Router...
I using the linksys 150n router on my desktop in the basement of my house, I have a verizon dsl supplied external modem westell 327w in the office that's working fine. how do i get 150n to work?
  • The router needs to be configured with the settings required by your ISP which is Verizon.
  • The modem should be connected to the Internet port of your router.
  • Verify with Verizon if you're connection is DHCP or PPPoE. If it is PPPoE then you should have a username and password from Verizon.
Please update me about this to assist you further with the installation of your router.
Dec 04, 2008 | Linksys Wireless-N WRT150N Router
Westell Linksys 327W
Ok right I love these issues. Here we go!! First I want you to determine if this is a no sync issue or if this is a no route issue. Know this is the difference between working with Verizon or working with Verizon On-Line. If you have a sync issue which means the DSL light is off or blinking, this would be a Verizon proper issue and is easy to have fixed, however if the DSL light is on and the internet light is off this means that you have not received a PPPoE derived address and thus while you have DSL (Digital Subcriber Line) sync you do not have connectivity to a gateway router to route you to the Internet. I want you to log into you DSL modem (http://192.168.1.1) then using your login ID and Password the one you configured for the Router not Internet access. And the go to the screen that show your DSL connectivity see if it is up or down *Remember DSL refers to the layer 1 connectivity, and PPPOE refers to the layer 2 connectivity". If the DSL light is on this meaans that you have to call verizon and say "My DSL light is on, but I am not getting an IP address which means my layer 1 connectivity is working, but my layer 2 PPPOE connectivity did not provide the platform for my layer 3 level to be built". so this now becomes a task of troubleshooting the layer 2 systems (PPPOE server, and IP Address delivery systems, and Redback SMS). Instead of a half hour of "is your modem plugged in". If your DSL light is off then your layer 1 systems are not working this could be anything from your modem to the ASAM ( ATM Subscriber Access Multiplexer ) system or DSLAM (Digital subscriber Line Access Multiplexer). In any case if the DSL light is off they just have to figure out why. This can be done at the central office by disconnceting your cable and pair and trying to sync up at the vertical shelf (Ca/Pr) or at the split bank. If they sync up the problem is outside, if they do not sync up the problem is inside the CO either at the Split bank or the DSL OE block. If the problem is in the CO they will fine and fix it. If the problem is outside, what you can do to expedite things is to take your DSL modem to the NID (Network Interface device) and connect to the phone line that has DSL on it and try to sync up there. If you can sync up the problem is inside of your house, if you can not sync up the problem is outside of your house prior to the NID and thus is verizon's responsibility. I hope this helps.
Sep 06, 2007 | Westell Wirespeed VersaLink...
WiFi Cards and Dell
They allow you to use your PDA on a wireless internet network.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Was there another solution?
I tried the conduit updater with no success--I wouldnt bother doing it.
Sep 12, 2005 | Palm Treo 650 Handheld
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
