How to connect hour meter of camsco product. - Televison & Video
If one pumps water from a source at a rate of 7 cusecs cubic meter per second, how many cubic meters of water would be pumped in 24 hours?
7 cubic meters /second = 7 X 60 /minute
= 7 X 60 X 60 / hour= 7 X 60 X 60 X 24= cubic meters per 24 hours or another way
7 X 86400 = cubic meters per 24 hours
May 26, 2017 | In Office Equipment & Supplies
Hi how to convert to kilowatt hour using this meter? Do we really need to multiply by 20
Yes, you do have do multiply, but not the number on the dial itself. This is a commercial or heavy residential use meter. They are geared so that each kilowatt hour measured by the dial is actually 20 kilowatt hours. This is done since some users use so much power that the meter could actually roll over during a normal billing cycle using a regular meter. So, if you are reading this meter to determine how many kilowatt hours you have used since the last reading, you simply read the meter as you would any normal meter to get the number displayed. Your photo reads 13525. That is your current meter value. If you last bill stated the meter value was 13501, that would indicate that you used 24 (13525-13501) times 20 or 480 kilowatt hours since the last bill.
Hope this helps!
Aug 15, 2016 | Office Equipment & Supplies
How do I unlock my accu-chek aviva expert meter?
For help with ACCU-CHEK products, please call 1-800-858-8072. Get meter support 24 hours a day, every day, and software support M-F 8am-10pm ET.
Dec 29, 2012 | Accu Chek ACCU-CHEK Aviva Meter
Need to reset my oil service light on my john deere lawn mower can you tell me how?
Hi and welcome to FixYa. I am Kelly.
The light (blinking notification on digital read out) will come on 1/2 hour before and remain on for 1/2 hour after the interval. If you pass your model number I can paste the notification data. It is NOT re-setable.
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running?
2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
^- This was a chart... It did not pst well at all. The key is that the interval underlined above is 1/2 hour before and after the service due period and it is NOT resetable.
Thanks for choosing FixYa,
Kelly
Jul 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
I just got a riding mower (D100) and it has 7 hours on it but the service notification just came on....i checked and it has oil. The belt came off while mowing last weekend but I put it back on and it...
Here are the is the process that the notification will appear:
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running? 2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
The notification should last for 30 mins before and 30 minutes after the service interval before it stops flashing. It is not resetable.
It does make one wonder why it started flashing at 7 hours vs 25 or 50 hours though. Possibly a battery was replaced and the running trime vs the service time intervals are not syncronized.
The service (SVC) arrow indicators will last for 1 hour. It will display ½ hour before the specified service interval and one 1/2 hour after the specified service interval.
The left "SVC" arrow will occur at 25 hour intervals (25, 50, 75, 100 etc.).
A "SVC" arrow pointing to the left will indicate that a general lubrication interval has been reached.
The right "SVC" arrow will occur at 50 hour intervals (50, 100, 150, etc.).
A "SVC" arrow pointing to the right will indicate that service is necessary for the mower and the engine.
Kelly
Thanks
Jul 16, 2011 | John Deere Garden
I bought the Phillips shm3300 headset, it was working fine, but one day i unplugged it whilst my friend was around my house, after he had left, i plugged it back into the same pluggins as before and i...
Try it in your computer or another device. If it works there, then the problem is with the original product. If it fails to operate in your computer, amplifier, etc. then perhaps a wired connection in the end plug may have fractured.
Connections can be tested with a Volt/Ohm meter also.
Jan 11, 2018 | Philips SHM3300 Headset
Operating manual for bw 30 & bg 30 timer counter
1) Identify product on following page:
http://www.hugo-mueller.de/elapsed-time-counters/mueller-bw-30-bg-30,p,en,8,34.html
2) Sales sheet shows model numbers and voltages and shows that product is hour meter:
BW30 is AC alternating current with choices 230Vac 115Vac or 24Vac
BG30 is DC direct current 12-48VDC
http://www.hugo-mueller.de/download/34_DB_BW30_BG30_BW22_GB.pdf
3) Hour meters normally have 2 terminals, but there is not a photograph of back of product.
Hoping you will photograph your product and post image on your website and add a comment to this thread with web address of image, along with other information you have.
4) Usual set up for timers and counters: terminal 1 is for black wire L or L1, and terminal 2 is for white wire N or L2.
If terminals are not labeled, then wires can be connected either way, but as you face terminals, terminal 1 is on left.
5) Wiring:
Hour meters are wired in parallel, not series.
For example hour meter on 240V pump: 2 wires go to pump.
Simply connect each hour meter terminal to one of the wires.
Another way to illustrate: If you test electricity using two-prong tester, you touch each tester lead to one of the wires. Hour meter connects same way.
6) How hour meters work:
Hour meters count number of hours electricity is turned on.
For example I have 240V Grasslin hour meter connected to water well pump.
Water well has pressure switch that turns pump on-off.
If hour meter is connected before pressure switch, then meter simply runs continually since it receives power all the time.
So hour meter has to be connected after the pressure switch. And then meter counts only when power is turned on to well pump. This way I see how many hours my pump runs and then estimate pump cost by multiplying hours x pump wattage.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Miller Electric Manufacturing Miller...
Do not know where to connect hour meter wire to the spark plug
One wire is the flexible silicone rubber wire from the spark plug to the ignition coil. You don't have to strip or connect the other wire, just wrap it around the spark plug wire a few turns.The current from the spark ignition will induce a signal into the hour meter that the meter uses to determine when the motor is on or off. I hope this helps and good luck.1b05a64.jpg
Oct 28, 2009 | 2006 kawasaki KX 250 F
Hour Meter not advancing
The connection should be on the back of the meter. You'll need to get behind it and probably remove it. There should be a bracket with a nut/screw attaching it to the back of the meter.
Take a look at this and let me know what you find.
Apr 28, 2009 | Garden
Televison & Video Logo
Top Televison & Video Experts
