Question about Pool & Spa
Can I buy just the Chlorinator Cell for a Minder X20CLS?
My Chlorinator cell is broken but the unit is still OK. Can I order just a cell?
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: pool chlorinator
Hi Chris, W/D here.
Here's a few things that you may or may not have checked:
1. You didn't state the age of the cell, or type. The generally last 2-3 years. I don't know how the power to the cell was checked, but clean the cell thoroughly before moving on. I use 1 gallon of muratic acid, and soak for about 5 minutes, then flipping the cell and soaking for 5 more minutes. Wear neoprene/chemical resistant gloves, and rinse thoroughly. Save the solution, as you can get several cleanings out of it.
2. Look for a fuse on your panel. The control boards are divided into areas of function. You'll need your wiring diagram, if the areas aren't clearly defined.
Hope this helps, --W/D--
Posted on Nov 10, 2011
  • 297 Answers
SOURCE: The green chlorinator light has not come on since
Are you waiting up to 10 minutes for the light to come on?Is the timer being set corectly? It is not immediate and could take up to that amount of time.
If this is not the case you can call intex and with a valid receipt they will send out a new unit up to 2 years after purchase
Posted on Jun 15, 2010
  • 297 Answers
SOURCE: did not filtering added salt destroy the
you probably didn't ruin it, just caused it to not know what to do.
In my opinion your problems started with actually being low salt.
In a panic and not realizing the proper way to test for 3000ppm you were probably low
you then got the new unit and were ready to have the same problem
If you do have high salt ( over 3500 ) you can create calcium on the plates and render them impossible to correctly read therefore giving alarms. you can also create severe corrosion on metal ladders thus putting metals in your pool and creating a new problem. Your pools chlorine will get eaten away quickly by the metals and with low or no sanitizer you will go green very fast.
So did you ruin the plates with high salt? I dont believe so. Your pool just wasnt in line abd if you had cleaned the plates with the vinegar treatment you still would have been in the same boat
all of the intex chlorinators are made the same but they are not exactly calibrated the same. They are close but not close enough so were one system might read the salt content ok the next may not
I am not sure if you were using any test kit at all but make sure you stay away from the salt test that reads in colors. The # test kit is right on the money where as the color one just gets you in the ball park
You must also remember that when it rains or you ad water because of splash out you may go low on salt. Just remeber 3000ppm
it takes a lot of rain or frsh water to alter your salt content but again if you are more on the low side of the 3000 then you would need to ad salt sooner
Please go to my name and look up my other posts dealing with low flow and gowing green
I am sure you will learn quite a bit and it should help you to have a more pleasurable experience with your pool..
start using the chemicals I mention in those posts cause once you go green it is hard and back breaking to get your pool back to clear
Posted on Aug 02, 2010
Testimonial: "you're the BEST - have learned a GREAT DEAL about my salt water chlorinator - MANY THANKS!!!!"
I have a Minder X-20CLS salw water chlorinator and it is constantle coming up with the error message E1... It sprung a leak near a few weeks ago and hubby use silicone putty to seal it... water is going...
Yes you can replace the cell itself. You can also clean the cell with Muriatic Acid. Mix 1 gallon muriatic acid two two gallons water. Dip the Cell in the bucket and let sit until the bubbling stops. Be very very careful when dealing with this Acid. If cleaning the cell does not work then you will have to replace it. Swim Time
Mar 04, 2015 | Pool & Spa
My blue essence controler says is working ok but the pool is not generatig cholrine
crack union after cell check with test strip if shows chlorine your pool might have phosphates and is using up the chlorine if so super shock pool that should solve your problem if chlorinator is not working try cleaning sensor and cell 4 parts water 1 part muriatic acid
May 15, 2014 | Raypak Pool & Spa
Chlorinator
sounds like cell is plugged with calcium (usually when high pH ) if cell is shorting out that will cause to trip reset unplug cell and see if it still trips off shut off system. if so take cell off saok in 4 parts water 1 part muriatic acid if still trips you need a new cell
Feb 18, 2014 | Pool & Spa
Turn off minute minder
Hi..
You can turn the minute minder to off on your lg by following these steps.
Go to Menu -> Settings -> Call Settings -> Minute Minder
Tap and Select Minute Minder to off.
Thanks..
Feb 05, 2014 | Cell Phones
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Jan 06, 2014 | Zodiac Lm3-24 Salt Water Chlorinator...
Pool chlorinator keeps beeping
The brand of unit you have, it is possible that you require more salt, or the flow lead has come away from cell, or water level is low, need more info, if all of the above is fine, it is most likely the cell is spent and needs replacing
Mar 02, 2013 | Pool & Spa
Why does my salt level get low
You can get a false low salt reading if your chlorinator cell is very dirty. Before adding more salt clean the chlorinator cell as per your maintenance manual.
Sep 01, 2012 | Intex Automatic Salt Water System for ...
Ok i have the intex 1600gph sand filter saltwater combo system and my pool hold 8000 gallons i can run the chlorinator 24 hrs a day and it will not get the chlorine and free chlorine above 1 the ph is 7.5...
Yes, what is your stabilizer level? It should be between 30 and 50 ppm. If the stabilizer is too low then the sun will cause the chlorine to dissipate faster than the chlorinator can produce it. Some salt chlorinator manufactures recommend 80ppm but that reduces the chlorine efffect. If you can't get the chlorinator working then using a floating tablet chlorinator is a good option to keep the pool open. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
585 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
