Question about Dryers
My cloth dryer does not start
When i want push the botton to start the dryer it wont start
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 03, 2012
appldoctom
  • 311 Answers
SOURCE: Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Posted on Jan 02, 2009
  • 61 Answers
SOURCE: dryer wont activate when botton is pushed on my
if by it wont acticate you mean nothing happens no noise nothing at all than you have a bad door switch 98% sure thats of course assuming you have power to the dryer
Posted on Jun 09, 2009
heatman101
  • 43501 Answers
SOURCE: Problem with the Whirlpool Dryers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 17, 2010
Testimonial: "thank u "
heatman101
  • 43501 Answers
SOURCE: kenmore dryer wont start with
Motor is going bad...if it has a capacitor, try changing that first...
heatman101
Posted on Oct 28, 2010
Jahn27
  • 1554 Answers
SOURCE: Clothes put in dryer, power
The dryer doesn't operate because the motor is not running and this is commonly caused by the blown thermal fuse which is located on the blower housing. This thermal fuse is wired in series with the motor and if it is blown open, power to the motor is cut and it will not run. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the other part (thermistor or cycling thermostat) on the blower housing if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 10, 2011
I have a power but dryer wont start after i push start button. i can hear the click sound after i push the start botton but doesnt start.
heatman101
Aug 20, 2011 | Samsung DV419AGW Dryer
Hi. when i push the start botton it clicks but wont run
heatman101
Jul 23, 2011 | Frigidaire FER341ZAS Electric Dryer
Kenmore dryer wont start with the start botton but if i push the drum while pushing the button it will start
heatman101
Oct 27, 2010 | Dryers
Problem with the Whirlpool Dryers ler 3624eqo Dryer wont activate when botton is pushed on my
heatman101
Sep 16, 2010 | Dryers
Dryer wont activate when botton is pushed on my elictric whirlpool dryer model ler3624eqo
Jun 09, 2009 | Whirlpool Dryers
Keep needing to reset washer dryer
Check the vent lines to be sure the path is clear
Mar 13, 2009 | GE WSXH208A Front Load Washer
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Dryers Experts
