Question about Microwave Ovens
Neff microwave oven H53W60N0GB runs full power on closing door without any setting required, no fans come on
This fault happened a while back but after a fortnight it just restored itself
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
  • 228 Answers
SOURCE: NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Posted on Aug 05, 2009
  • 574 Answers
SOURCE: Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Posted on Sep 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Posted on Oct 09, 2009
Testimonial: "Thanks for your help. Customer Services were no help. Can you please advise which type of caulking to use."
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
Oven accidentally operated without any contents and cut out with a smell of burning. Subsequently the oven only runs for approximately 22 seconds before stopping. Any ideas?
It will require a new magnetron and possibly power supply for it. The magnetron will destroy itself if it has nowhere for the energy to go.
Feb 14, 2011 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
How to repair venting fan in neff micro/oven
what is the fault precisely?is the fan not working?If so, you have to remove the fan carefully after opening the panels & removing its thimble connectors & replace it, Voila!
Jan 03, 2010 | Neff B7740N0GB Microwave Oven
Glass continually shattering on combination neff oven
That's a huge gap.
Oct 09, 2009 | Bosch Microwave Ovens
Microwave wont run, displays E 10 on the screen and also microwave fault, press stop to acknowledge, just changed the door.
e 10 is the internal safety fuse has blown this often happens if door is altered for any reason moving the door can effect the setting of the monitor switches these are set to a high tolerance to avoid operation of microwave with door open changing the door has shifted these settings and blown the fuse, replacing the fuse may be enough to get it going but it should be checked for leakage.
Jun 11, 2009 | Neff H5470 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
