Question about LG 42LC2D 42 in. LCD HDTV
I got LG32lh2000, the scren blink twice and go off again
    Top Expert:
  • LG Master
  • 14,553 Answers
Power supply or related to that---sounds like the two blinks is a error code----a very general indication of what the problem may be.
Posted on Dec 03, 2012
I need the steps to program the urc4021 remote, as well as the code for the sanyo tv
To program the One-For-All URC4021, first turn on the TV manually (or with the original remote). Press the TV button on the URC4021 once. Then press and hold the Set button until the LED blinks twice. Now you can enter a code directly and test it. For Sanyo TVs, the only programmed code is 0154 . If the LED blinks twice, press Power to attempt to turn off the TV. If that works, you can turn the TV on again and test if the other buttons on the remote work with your TV. If the LED doesn't blink twice, repeat the steps from pressing and holding Set. (If you wait too long before entering the code, the remote will leave the programming mode.)
The URC4021 has a code search mode. Press and hold Set until the LED blinks twice, then press 9 9 1 . If the LED blinks twice again, alternate between pressing the Power and TV buttons until the TV turns off. Then press Set to lock in that code and test the remote again.
I hope this helps.
(Note: if your TV is newer than the remote or released within 6 months of the remote being programmed, this code may not work. The URC4021 documentation gives March, 2004 as the copyright date. That suggests that the codes may not work with devices built in 2004 or later.)
Sep 29, 2015 | Sanyo Televison & Video
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
My screen has gone pink on my lg32lh2000
check all scart lead are in turn off and on again if no differnt i would say it time for new tv sorry for bad news
Feb 02, 2011 | Televison & Video
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
Aug 28, 2010 | One For All URC-3021 Remote Control
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I tried to restore to factory settings and my computer went to a blank scren with a white blinking dash in the top right corner. help
Are you restoring from CD or from a built in restore feature. If you are restoring from CD, clean the CD's first and try again.
Jul 30, 2009 | Acer Aspire 5720-6661 Notebook PC
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
