Question about Fujitsu Heating & Cooling
Fujitsu AOT24RWGL airconditioner leaking
Fujitsu aircon leaking on left side inside room
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
  • 140 Answers
SOURCE: Water coming from inside unit of Fujitsu airconditioner
Go to http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=36 to get the manual. Any questions please ask. Please rate me so I know if I helped.
Posted on Dec 30, 2008
meBNme
  • 334 Answers
SOURCE: water leaking into the house - model AOT24RWGL
Either the drain line is clogged, or there is a hole in the pan.
Get a powerfull wet/dry shop vacume.
Attatch it to the end of the drain pipe and seal it tight and pull out any dirt, mold crud blockages.
Take the panel off so you can access the drain pan under the evap coil. Clean that out as well with the vac.
Once its nice and clean, poor a gallon or so of water into the pan bein g carefull to not pour to fast.
Make sure that the line is drainign well and look for any spots where there may be a crack, hole etc in the drain pan where water may leak out
Posted on Jan 01, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
  • 45 Answers
SOURCE: Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Posted on Jun 09, 2009
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
Drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Jun 28, 2009 | Fujitsu Heating & Cooling
Jun 08, 2009 | Panasonic Room Air Conditioner CWXC104HU
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
2006 ford focus airconditioner couldn't cool contineously
Sounds like it needs a coolant recharge. Many parts shops in the US will sell DIY AirCon recharge kits. Check the DIY sites, but basically, you can do this recharge without opening the hood-I believe the high-pressure connection is in the left side front wheel well.
Feb 21, 2009 | 2006 Ford Focus
Water leaking into the house - model AOT24RWGL
Jan 01, 2009 | Fujitsu 24R1 Air Conditioner
Regassing of fujitsu splitsystem airconditioner
All split ac can be regassed, but if it was only installed recently and the gas has leaked out then it will either be a manfactures warranty job, or if it was poorly installed it should fall under the warranty of the installer. most cheaper installers however only give a 3-6 month warranty on thier work if they give one at all. If it is uses either R410 or R22 gas (it will say on the outdoor unit) than any liscensed and i stress liscenced installer can fix the leak and regass it.
Feb 13, 2008 | Fujitsu 36CS Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
