Question about LG VX8350 Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I need some help with how to disassemble my VX8350 so I can replace the Inner keypad housing which uncludes the female portion of the hinge. I have removed the 4 screws that I can find inside the battery housing case lid, but it does not seem to release the inner keypad housing from the base.
  • Anonymous Mar 03, 2009
    the hinge plastic broke into two pieces
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Posted on Feb 22, 2009
  • jsrjs Feb 22, 2009
    GOT IT!!!! It appears, if your looking at the front of the phone (keypad) the hinge is only on the rights side, the ribbon cable runs through the left side. So I flipped the top part of the phone over and then very gently bent and then pulled the screen assembly away from the keypad assembly. I was succusfully able to repair to phones this way. One with only a broken hinge and the other with a broken screen. They are both working again.
This phone has 5 screws. one is covered at top with a plug that needs to be removed first. then phone will come apart , just have to slowly seperate at seam but slowly and carefully
Posted on Apr 08, 2009
  • sns7276 Apr 08, 2009
    There is a movable pin that will release flip top and the left side has a copper ribbon, possibly antenna.
  • 481 Answers
You can in fact separate the two halves of the phone at the hinge to get the ribbon cable out. You just need some manual dexterity.
The outside of the hinge (on the keypad shell) is hollow on both sides. On the ribbon cable side, the inside is also hollow, and slips inside the outer socket using a hollow pipe-in-pipe joint. The ribbon cable runs through both hollows.
On the other side there is a solid post (usually yellow) extending from the inner hinge (display shell) into the outer socket (keypad shell). The trick is that this post is spring-loaded. There is a tiny port in the keypad shell through which you can push the post inward until it clears the outer hinge socket. You will need a skinny angled tool like a 45° spring hook. Then the two parts of the case will separate and you can remove the ribbon cable and replace the upper electronics if you wish.
Posted on Sep 19, 2009
    Problem Solver:
  • 6 Answers
The cable running from the earpiece top half of the phone down in the main bottom half can be unplugged. There's a large flat connector on the bottom half of the cable. You can pop it out gently. Then you can feed the cable through the top half of the case. The case is replaceable, just be very careful. To reassemble you need to flex the bottom portion of the case to spread it a bit. This will let you ease the hinge top part into it.
Posted on Apr 14, 2010
Answer LG without flipping it open.
By default, it's set to "any key" which means when you press any key on the keypad, calls will be received. If it's then go to call settings and set the answer options to "any key" and save the settings.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Verizon Communications LG VX8350 Cell...
The keypad volume is stuck on earpiece & I can't hear without earjack how can I clear cell?
Called Verizon. Removed battery while phone is still on. They also had me update the phone via *228, option 2 but I don't think that helped.
Jan 22, 2010 | Verizon Communications LG VX8350 Cell...
Had 3 of this vx8350 from verizon break on the same right hinge.
I have the same issue and am considering cancelling my Verizon service because they won't replace it without paying $50.
Sep 17, 2009 | LG VX8350 Cellular Phone
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
Hinge broke on my Verizon LG VX8350 phone
I called customer service and spoke with someone different who is sending me out a new phone free of charge.
Jun 22, 2009 | LG VX8350 Cellular Phone
Hinge broke on LG VX8350 Phone
I had the same problem with my VX8350 and when I called customer service they told me the same thing, but then I took the phone to a Verizon company owned store and they replaced the phone for free as it was a know problem with this model.
May 27, 2009 | LG VX8350 Cellular Phone
You need to march right back to Verizon and demand a new phone. If you do a search on the internet, there are multitudes of people with the exact same broken hinge problem. This is a design defect and should be replaced no questions asked. Verizon knows about this problem. I had my phone less than 6 months when my right hinge just broke...no dropping or other damage. I went in and they replaced it free of charge - because they knew about the problem. That was just a month ago and my right hinge broke again today...one month later. I am going to demand a new phone or they will be facing a class action law suit. Who ever told you this had to be filed with insurance and that you have to pay $50 did not know what they were talking about. Do what I am going to do and print off all of the complaints and present them to Verizon.
Jan 31, 2009 | LG VX8350 Cellular Phone
I lost the little plastic cover that keps dust and debris out of the port that the charger plugs into on my LG VX8350 portable phone. Can I buy a replacement?
I've had my phone for over 1 yr without that little thing. Never had a problem. Call local Verizon store they can tell you.
Jan 28, 2009 | LG VX8350 Cellular Phone
Can't find driver for usb data cable for Verizon LG VX8350
there should be an enable usb mode on the phone itself if not then you can use a program called bitpim which is an excelent program for syncing almost any and every phone with your pc via usb and will automaticly detect the driver required and offers help on how to connect each phone, the site to download it is: http://www.bitpim.org/
it is third party software so completely free to download and feel free to scan with any anti-virus and/or anti-spyware it is 100% clean
Dec 24, 2008 | LG VX8350 Cellular Phone
i want to master my lg cdma kg800 for downloading mp3 ,picture,......etc
would you mind help me please ....... thank
Jun 29, 2008 | LG KG800 Cellular Phone
LG VX8350 Cellular Phone Logo
6,196 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
