Question about Dell Dimension 2350 PC Desktop
Total newbie here - how do I add more memory to my DELL Dimension 2300? I have my cpu open and i am replacing my fan also.
    Novelist:
  • 176 Answers
Well your Dell 2300 has a total max. memory of 1 GB from both slot.
If you already have (2) 512MB RAM in the slot then thats the max it can handle.
Dell 2300 only has 2 memory slots. Memory comes in 1- 128MB, 256MB and 512MB PC-133 DIMM modules. So if you want to max it out get (2) 512 MB PC-133 DIMM.
Note:
You must wear a static strap or ground yourself first on the computer chassis before you touch any thing inside your computer
to discharge any static electricity
For further instruction check this out:
http://support.dell.com/support/edocs/systems/dim2300/replace.htm#1101964
Posted on Jan 11, 2009
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
CPU running slow - I think the pentium went into a slow mode when the CPU fan failed. Dell BIOS does not have an option to restore to normal speed as Phoenix BIOS does.
Do you ever get a warning of low virtual memory? If so, go to microsoft.com. Then type in yyour operating system. It will then give you the appropriate propram to clean it up.
Feb 27, 2010 | Dell Dimension 2300 PC Desktop
I have a dell 2400 an it will not come on but the mom brud will lit up can you help
If you turn it on and there is no sound of a fan running or the hard drive spinning up, then you will be needing a new power supply.
If you hear the fans running but there is no signal on the monitor, you might have a different hardware problem. In that case, open the case and remove all of the connections to the hard drive and CD. Leave only the cpu and memory connected. Then try to start it.
If you have no luck, try to use a different monitor.
If still no luck your motherboard is bad or the CPU is bad.
Nov 20, 2009 | Dell Dimension 2300 PC Desktop
How to remove the cpu fan cover
on my 2600, the cover just lifts off the heatsink, and the fan is attached with stretchy rubber things that allow you to just pull it off. What are you trying to do?
Oct 12, 2009 | Dell Dimension 2300 PC Desktop
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
How to add extra memory card in the mother board
well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Jun 23, 2009 | Dell Dimension™ B110 PC Desktop
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
Noisy fan old older computer
Buy a new one here for $10
http://cgi.ebay.com/NEW-DELL-DIMENSION-2350-2300-CASE-FAN-92mm-x-25mm_W0QQitemZ250245854784QQcmdZViewItem
May 10, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Dell Dimension 2350 PC Desktop Logo
82 people viewed this question
Alun Cox
