Question about Casablanca Fan Dryers
Casablanca remote control fan 6980/5 is turning itself on-why?
Fan and light come on by themselves in last few weeks. fan over 2 years old and never happened before
CompuGuy44
  • 432 Answers
SOURCE: fan won't go on
It's probably the electronics inside the fan. They may need replacing. http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Posted on Jun 27, 2007
ceiling-fans
  • 20 Answers
SOURCE: need a replacement fan speed potentiometer.
Okay -- first off, I don't know where she got that number from, but that's idiotic.
The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
HOWEVER---
Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
I hope that helps! If you have any other questions, please feel free to ask!
Posted on Jun 17, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
ozark333
  • 396 Answers
SOURCE: Fan light is turning itself on
I had the same problem...funny ...NOT! Wife almost killed me!
Pull down the guts and change the frequency switches. Usually little micro switches on the receiver up inside the housing. They call them DIP switches. Change the swithces in the wireless remote to be the same setting. I changed mine and now maybe once in a while a stray radio signal (garage door openers, radio signals, airplanes...all use frequencies near or harmonics of the ones these fan controls use) kicks mine on, but not every night! She stormed out and said..."Are you playing with the lights....I'm trying to sleep!"....It wasn't funny....but it kinda was!
Posted on Sep 29, 2009
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
Casablanca fan 6980/5 can not start
Call 1-800-715-0393. Have model# & serial #
Apr 16, 2013 | Dryers
I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with...
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
Sep 04, 2008 | Casablanca Fan Versa Touch2 W-72 Remote...
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Fan turned on by phantom signal
If you have more than one fan and they have remote controls they may be set to the same frequency. You can re set one fan to operate at a different frequency. The instructions ar in the manual or online.
May 26, 2008 | Casablanca Fan 3245T Ceiling
Dryers Logo
74 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
