Question about Cameras
SD card applications not found
When turning on my daughters Vtech Storio the screen says "SD card application not found" & then turns off. How am i able to get the storio to work again, my daughter is devistated that she is now unable to use it ;-(
DUMPLINS559
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Posted on Feb 05, 2009
SOURCE: y is it not working
The camera "thinks" it's connected to a TV. We had the same problem. My wife used a bobby pin to "trick" the camera into thinking it was being disconnected from the TV by probing the pin into and out of the TV connector on the side.
Posted on Feb 24, 2009
SOURCE: Vtech kidizoom camera does cannot find SD card
I had similar problem. In windows i formatted the SD card as 'FAT' rather then 'FAT32' (right click on card and select format) and that made the camera recognise it!
Posted on Jan 14, 2010
SOURCE: Our Vtech kidizoom pro wont recognize the SD card.
Format SD card as FAT and not FAT32. :-)
Posted on Sep 18, 2010
Kensolutions
  • 455 Answers
SOURCE: Sony Cyber Shots camera, turn the power off and on again problem
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Posted on Oct 21, 2010
Storio vtechi downloaded the storie from the website to the file manager but cant get them to transfer to the storio, it startts to transfer then says error!!
are you using an SD card? You need an SD card for this. If you already are and you are still getting an error, make sure that the SD card is not write-protected.
Nov 29, 2013 | Vtech Storio Interactive E-Reading System...
Vreader/storio sd card update failed
Try to update your SD-card from another computer. That worked for me.
Jul 13, 2012 | Vtech V.reader Animated E-book System
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
My Vtech V-reader freezes on calibration screen
I just found a solution to this: Turn off the vreader, then press & hold the help "?" button. While holding the "?" button, press power. My system bypassed the calibration step and booted correctly.
Jan 05, 2012 | Vtech V.reader Reading System
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
Dec 28, 2011 | Vtech V.Reader Interactive Reading System
How do i fix my vtech storio the screen is just blue and it wont work ?
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the Storio, but at least you'll get it working again.
vtech could have made it a very simple problem to solve just by adding in their customer support: Blue Screen? follow these steps. But they don't, so here's how:
You'll need an SD card with at least 64mo of free space. If you want to use the one from your camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website, but it took me a while to get there)
For the US version
http://contentcdn.vtechda.com/vtechkidsDownload/US/VReader/Tool/Recover/US-engRecoverCardTool.exe
For the Canadian english version
http://contentcdn.vtechda.com/vtechkidsDownload/CA-eng/VReader/Tool/Recover/CA-engRecoverCardTool.exe
This is the link to the website itself:
http://www.vtechkids.com/download/ca/en
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that. And since there's no reset button on the Storio, this is the only way to erase the 100+ drawings that your child saved.
Hope that helps
Dec 17, 2011 | Lands Phones
It keeps saying touchscreen calibration utility touch crosshair to calibrate. we'v done everything that we could to fix it. it will not go back to the page with activities.
I need help I buy my son V.reader for Christmas it say Touchscreen Calibration Utility Touch Crosshairs to calibrate. I need help? how do I fix it?
Aug 19, 2011 | Vtech V.reader Animated E-book System
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
