Question about Vertex Standard VXR-9000 Desktop Repeater
E7 in display - Vertex Standard VXR-9000 Desktop Repeater
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
E7 refers to an internal error in your unit.
Please do the following to get expert help:
join yahoo group specific to your radio Make/Model, give the team there as much info regarding your unit as you can, as this will help them find a solution for you, plus you can download manuals, diagrams and other goodies for your unit, and it's all free.
I wish you well and hope I have been helpful.
Best regards,
Peter
Posted on Mar 07, 2013
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
What does error code e7 on a Dyson am 05 mean?
Hi there, it's Jack at Dyson.
If your Dyson Hot + Cool heater is displaying an E7 error code, we will need to take some further details via our Helpline to resolve this for you.
When you have your machine to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide assistance.
We'll look forward to speaking with you.
Oct 09, 2014 | Dyson Inc Am05 Hot Cool Fan Heater -...
My tx500 has a e7 on display and wont start what can i do
Dear Sir:
has 2 options this error:
1) elevation motor: a) motor faulty b) grease and lube the gear c) adjust the potentiomenter d) gear and bars lube e) main motor board faulty. see my personal TIPS FOR HELp.
2) see the attached diagram for adjust the reed swithc, clean, and tight the ribbon cable from keypad , and tight the connector from display board vs lower board. b) the display boad can be faulty.
In short after you did the adjustment,RUN INMEDIATELY, the software calibration for diagnose and troubleshooting.
May 01, 2012 | Sportcraft Exercise & Fitness
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Vertex Standard VXR-9000 Desktop Repeater Logo
147 people viewed this question
Top Vertex Standard Radio Communications Experts
rostit
tvopft
Level 1 Expert
John L radiodude365
Are you a Vertex Standard Radio Communication Expert? Answer questions, earn points and help others
