Question about Toshiba Satellite M45-S2652 Notebook
Cd/dvd drive wont open
I press the button to open the disk drive..the yellow light flashes but it does not open ...please help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
You could try to manually eject the CD, may be the mechanism is stuck. Have a close look at the CD tray, there should be a tiny hole, then find a paper clip with a wire diameter that nicely fits this hole and poke it in there, this will release the CD tray and open it so you can retrieve the CD.
Hope this helps
Posted on Jan 12, 2009
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
I have dell 1420, the cd/dvd room wont open. also it didnt flash the yellow light. i tried to open it with pin, it worked but when i put the dvd it didnt detect the dvd.
Hello.
Your CD/DVD drive is probably faulty and needs to be replaced.
But, try a CD/DVD cleaner to see if it can be salvaged.
Hope this helps.
May 24, 2011 | Computers & Internet
The cd drive spins and the light flashes but the laptop doesn't seam to see a disk.....a known good disk?
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 25, 2010 | Toshiba (K000833290) DVD Drive
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
My toshiba computer optical disk drive wont open but it keeps flashing i dont know what to do! help me please
Hi there.
There are a couple of ways to open the CD/DVD tray.
Firstly you can right click on the CD/DVD icon in my computer/computer and select eject from the sub menu, or if you look very close at the CD/DVD drive near the eject button for a very small hole, if you see one get a paperclip, straighten it out and push one end in the hole until the tray ejects.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Wont eject cd
there is a safety release in all disk drives take a paperclip and push it into the small hole on the face of the drive and the drive should pop open
May 12, 2009 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
CD tray does not open when Button Pressed
does the tray open when you right click on the drive icon in "My Computer" and select "eject"?
Oct 25, 2006 | Sony DRU-810A DVD RW Dual Layer Burner
Toshiba Satellite M45-S2652 Notebook Logo
247 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
