Need CRT base from where can I buy? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check this link to know the availability.
Posted on Dec 04, 2012
  • david schembri Dec 04, 2012
    Thanks for your reply the problem is that at Alibaba they supply only in large quantities
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Picture t v tube 19varp4
If you wish to get the circuit diagram of CRT base boards, http://electrohelponline.blogspot.com/ check this link. Pull up older posts there. Circuit diagrams to some popular model CRT TVs are given. I can't include it by here by this window. Check the site with patience.
Jun 03, 2013 | Televison & Video
Disney DT1300-C 13
You can buy it from most of the electronic spare part selling shops at your town.
Apr 18, 2012 | Disney DT1300-C 13" TV
The picture looks like a 3d picture without the glasses.
hi,
If the tv is crt one then you have to check the base socket of the three crt gun, red gun, gree gun, blue gun . If the picture looks out of focus then there is problem with the crt base socket. After a long time of use the crt bases connectros will get corrode and it will not have proper conatct with the connection pins of crt guns. you can see this base sockets in the base board on the neck of crt guns. Remove the base board and remove the sockets and replace with a new one. This will give a good picture. The crt base socket will look like on in the picture
ajin_g_66.gif ok
Sep 23, 2011 | Hitachi Televison & Video
Can i use my 21'' Onida tv kit on my 17'' LG crt monitor pictur tube ?
You can use the tube alright but there are corrections to be done on the tube and the CRT base needs a rewiring
Secondly the convergence, the horz/vert will not be correct and truthful.
You will get a picture but the aspect my differ a bit.
So make the alterrations on the CRT base of monitor and rewire.
Helpful?
Aug 25, 2010 | Televison & Video
Green and red lines on tv
What kind of projection tv are we talking about a lamp based unit? or a CRT based one? If it is a lamp based one then you could have a dirty light engine which is expensive to replace. If it is a CRT based one you could have bad convergence IC or one of you tubes is in overdrive and the screen voltage needs to be adjusted.
Oct 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Please help me with my sharp t.v model no.21V-A300XB
The problem could be with the CRT base socket, why don't you try replacing that? It is not a costly component, and it is easy to replace. Make sure you buy the exact same thing and verify connections.
Jan 02, 2008 | Sharp 27C-240 27" TV
Traditional toshiba TV picture problems
it is due to poor focusing please check 1 set with focus control fitted on flyback transformer, 2 check focus control wire comes to crt base is loose or some foreign material deposited on it. 3 crt base loose contact. 4 if tv is old then there is a possibility of crt is getting weak. if you are not a technical person do not open set as tv has very high voltage inside. hope this will help.
Oct 01, 2007 | Televison & Video
Color Problem
buy a new one! IT WILL EXPLODE
Apr 28, 2007 | Compaq MV 540 15" CRT Monitor
Red screen
Christ, why did you disturb the bias settings? Which stupid @#$% told you to that? The red color was most likely a blown Red Output Transistor, or something as simple as a bad CRT base. Now, I suggest that you switch off the TV, wait for a couple of hours, open the set, and very slowly and carefully pull the CRT PCB (along with sockets base. Then clean the CRT terminals (use a fine emery sheet.) Also check the base for dry (cold) solders. Replace the CRT board. Picture should be normal. If problem persits, then it is definitely the Red Output Transistor or associated components. Get a professional to have a look.
Aug 23, 2006 | RCA F27628 27" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
