Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1993 GMC Suburban K1500 Air Condition Fan and vent choice problem
Two problems:
1) ac/htr fan operation is intermittant, works great when it works but the switch doesn't always turn it up, down, or on. I think its a relay fault but I cannot find the relay. Where is it.
2) tick, tick, tick, tick noise from under glove box area when I start up, shut down, or alter the ac vent choice controls. How do I fix this?
My blower motor fan will shut off and on by itself, without even touching it. When I am on a bumpy road, it will usually turn itself back on. I had the same problem on my Ford Crown Vic. It turned out to be the blower motor speed controller. But my Chev silverado has a resistor pack. Dont know if that is the problem or not.
I would check the large wire that attaches to the blower motor under the right side of you're dash. The connector plug sometimes burns and melts. make sure it is tight.
Posted on Jan 11, 2011
  • 3 Answers
Faulty relay, there may be three of them, had the same problem on a 91 GMC truck
Posted on Feb 02, 2009
  • 34 Answers
This is common gm prob with your vehicle. the control unit needs to be replaced. and as for the resistor pack im not sure where you are looking, but in the dash in the same area as the heater controls is a gray or silver box and this is for the radio.
Posted on Jan 12, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Have a 93 sierra,cannot get air to defroster,can hear fan but will not blow on windshield ?
Can you hear your blend door at all. Does it change into other settings. Like to floor and vents. It could be your blend door actuator.
Jan 05, 2013 | 1993 GMC Sierra K1500
THE AIR CONDITION AND FAN WONNT BLOW OUT FRONT
follow the vents from inside to the fan to make sure there not clogged
Nov 01, 2009 | 1993 Jeep Wrangler
1993 Suburban rear ac is great front is warm.
There is a flap inside the venting behind control panel. This flap directs the flow of hot/cold air. It is controlled by a vacuum operated actuator that tend to fail. This hose runs in to the hoses on back of control panel switches.
Jul 17, 2009 | 1993 Chevrolet Suburban
My 99 suburban front Ac fan does not work, if I drive over 40 mph there seems to be cool air being pushed thru if you put your hand infront of the vent.Back AC works good. heat works almost the same way....
It's either your fuse, blower motor or the switch. More than likely the blower motor. You'll have to take it out and get a new one. Use a test light to see if there is power at the motor when the key is on and the fan switch is on. If power is present, then your motor is gone.
Jun 10, 2009 | 1999 GMC Suburban
AC/heater fan on 1992 Buick LeSabre only works intermittently
Could be a bad control switch, relay or connection and ground at motor itself. Since it's intermittent, check voltages when it's working, then again when it's not. Wherever voltage stops, that's what you need to replace. Don't wait on this...when completely inoperative it gets much harder to find the problem!
Jun 09, 2009 | 1993 Buick LeSabre
Front heater fan control switch gets hot and melts. Why?
this is an easy one, the blower motor is drawing to much current, this happens as they wear out, replace the blower motor aNd all will be well in chevy land.
Feb 10, 2009 | 1997 Chevrolet Suburban
Fan function switch won't blow air other than htr/defrost mode
check the vacuum on the control unit, or you can also check the cable that controls the direction doors. hope this helps
Jan 11, 2009 | 1998 Ford Ranger SuperCab
97 gmc suburban heater fan only works on hi
hello , it is located under right side of instrument panel , on heater housing . an extra clue is the wire connector going to it has a dark blue, a light blue , a tan and a yellow wire on its connector , you will only see the outside of the resistor as the actual resistors ago inside the heater case .and also this is 1997 gmc suburban , even tho listed under 1993 gmc suburban , same instructions . hope ya fix yer problem .
Jan 04, 2009 | 1993 GMC Suburban
MIKE.
#1) YOU PROBEBLY HAVE A BAD BLOWER MOTOR OR POSS. A BURNT CONNECTION @ THE MOTOR. IF THE FAN WORKS ON ALL SPEEDS EVEN INTERMITTENTLY. THEN THE BLOWER RESISTOR IS OK WICH CONTROLLS THE VOLTAGE TO THE MOTOR TO GET THE DIFFERENT SPEEDS. WHEN THE RESISTOR BURNS OUT THE FAN JUST WON'T WORK ON CERTAIN SPEEDS. THE "RELAY" IS ONLY USED FOR HI-SPEED FAN USE. TRY HITTING THE MOTOR WHEN YOU GET IT NOT TO WORK AND IF IT STARTS THN YOU HAVE A BAD MOTOR.
#2) THE NOISE YOU HEAR WHEN TURNING THE IGN. ON AND OFF IS PROBABLY THE DEFROST DOOR CONTROLL ACTUATOR/MOTOR WICH HAS A POTENTIOMETER IN IT THAT TELLS IT WHEN TO STOP MOVING AS IT REACHES THE CORRECT POSITION. WHEN YOU TURN THE KEY OFF IT BY FEDERAL LAW HAS TO RETURN TO THE DEFROST POSITION IN CASE OF FAILURE. THE LITTLE SPLINES IN THE MOTOR OR ON THE SHAFT CAN GET STRIPPED WHEN THIS HAPPENS. TRY DUPLICATING THE NOISE BY SELECTING THE DEFROST ON AND OFF WITH THE KEY ON.
I WILL CHECK FOR YOUR FEEDBACK LATER
Aug 05, 2008 | 1993 GMC Suburban
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
468 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
