Question about Water Heaters
My electric water heater geyser shows red light which says "cut-out" and water does not heat after 15 mins
Country : india brand : euro geyser
5 Suggested Answers
  • 25 Answers
SOURCE: rheem 71 40d elecrtic water heater not heating
If it is an electric water heater, there is no pilot light. You could have bad elements or bad thermostats. Be careful working on an electric water heater, as most use 208-220 volts!
If it is a gas water heater, it could be a bad thermocouple, ignitor, gas valve.
My advice to you is to call a qualified service company to come repair your water heater.
Posted on Jul 10, 2009
  • 2712 Answers
SOURCE: Electric Water Heater Problem
When an electric water heater fails to heat water, either the power to the water heater has been interrupted or there is a problem with the controls or the heating elements. 1) Be sure electricity is being delivered to the appliance. Check the main switch on the water heater and the circuit breaker (or fuse) that serves the water heater. 2) Check the high-temperature cutoff in the water heater. Open the panel, and push the reset button. 3) If these steps don’t solve the problem, call an appliance repairperson.
Posted on Aug 27, 2008
Nomodo4u
  • 863 Answers
SOURCE: I have a atwood propane hot water heater. The
Cheap Fix- You need a new thermocoupler Spendy Fix- Pilot light ignition switch
Posted on Nov 19, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Rheem Electric 40 gallon water heater not providing heat
The elements may be burnt out you can check them by an electrical light tester. There is a lower and an upper element. If the tester lights up element is good. I hope this helps, please rate if the answer was helpful. Have a great day. Jeff
Posted on Apr 04, 2010
My kwikot geyser trips when I turn it on its 7 year old
If breaker trips check
- elements being to high in ohms resistance (worn out)
- shorted elements
- short to ground
- improper wiring or voltage per nameplate
May 19, 2017 | Water Heaters
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Water Heaters
Instruction to repair leaking geyser panel on 150litter kwikot geyser
It sounds like the tank is leaking. Without the information as to where the leak is the only answer I can suggest is to replace it.
Nov 28, 2014 | Water Heaters
Fly Geyser in NW Nevada, does it exist?
Wow this is wierd but here goes... (from WIki) Fly Geyser is located on the private Fly Ranch in Hualapai Flat, about 0.3 miles (0.48 km) from State Route 34.[1] The ranch is currently owned by Todd Jaksick There is a high fence and a locked gate topped with spikes to exclude trespassers. The only access is a dirt road, but it is large enough to be seen from the road.
It is not an entirely natural phenomenon; it was accidentally created by well drilling in 1964 exploring for sources of geothermal energy.The well may not have been capped correctly, or left unplugged, but either way dissolved minerals started rising and accumulating, creating the travertine mound on which the geyser sits and continues growing. Water is constantly released, reaching 5 feet (1.5 m) in the air. The geyser contains several terraces discharging water into 30 to 40 pools over an area of 74 acres The geyser is made up of a series of different minerals, but its brilliant colors are due to thermophilic algae.
Sep 14, 2014 | Water Heaters
Junkers gas geysers
What is a, "geysers pilot"?
Jul 14, 2014 | Water Heaters
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
What is an anode in a geyser
The anode rod is part of water heater, not part of geyser:
Here are anode rod resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
The geyser is compressor that attaches to top of water heater, and converts ambient room temperature into heat to heat water using the refrigeration cycle in reverse
Add a comment and fixya might notify me so i can more informeation if needed
Jul 08, 2013 | Water Heaters
Water Heaters Logo
1,107 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
