My Lenovo Y410 laptop is getting a black screen on startup, i'm unable to enter into BIOS also to diagnose something. Pls help me
One fine mng i'm getting this black screen, once i have removed my battery powered directly through the cable then it went upto password screen after that it has thrown an error msg "Hardware failure" after that when i switchon it on battery & direct power i'm getting the same black screen.
    Scholar:
  • 156 Answers
That may be a problem with either motherboard or HDD. contact a laptop technician, not a common pc technician in your local area.
Posted on Dec 03, 2012
bhagyavichar
  • 414 Answers
SOURCE: i get a blank screen when i startup in my lenovo
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor fromcabinet..see if raster or 'osd' is appearing on the monitor screen..ifso monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
5) a) see if ur hdd is noisy or emitting any 'ticking'noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to breplaced..
6)remove/clean dust neatly..dust is non-uniform innature n may cause jam/short circuitry/excess resistance n manymore..resulting an increase in heat..
7) open the CPU Heat-Sinkwith fan out of the socket..put some "Heat Sink Compound" (available inlocal electronics chip level spare market) between the cpu/processor andthe CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..gothrough the mb's south bridge n the circuit lie around atxconnector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smpsviz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', orpwm switching regulator circuit..look for defectiveprotector-transformer/resistance(esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hv a licensed and UPDATED antivirus installed (iprefer avg/kaspersky, remember, without updation a full version antivirusis useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart;
b)'Error Reporting' right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when criticalerror occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
rockitman187
  • 2559 Answers
SOURCE: how to reset bios password FOR LENOVO 3000 LAPTOP
This is copied directly from the Lenovo website.
Note: Do not forget your hard disk password! Keep it in a safe place. If you forget your hard disk password, there is no way to reset your password or recover data in the hard disk drive. Neither an IBM authorized reseller nor IBM marketing
representative can make the hard disk drive usable.
Posted on Jan 14, 2009
Hollyecho
  • 313 Answers
SOURCE: Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Posted on Jul 03, 2008
harvester3
  • 181 Answers
SOURCE: HP laptop Pavilion DV 4000 Password
First, DON'T SHORT ANYTHING ELSE OUT!
Now, tell me how one sets a bios password, then just forgets it?
If you can prove ownership on a laptop as new as a DV4000, there are plenty of posts out there describing the proceedure for recovering the system. Occasionally even HP will helpout legitimate owners in situations such as this.
I'm sorry, but this isn't the forum for this particular problem.
Good luck
Posted on Nov 25, 2007
Dipu007
  • 2110 Answers
You can reset BIOS password by removing CMOS battery from motherboard and re insert again...
Posted on Dec 10, 2008
My lenovo y410 screen keeps shaking
Go to BIOS and check if the screen will shake in there if not try to uninstall and re-install the video driver that you have. If the screen is also shaking in BIOS it means there is something wrong with your video card.
Nov 19, 2012 | Lenovo 3000 Y410 Laptop
HI..i have a lenovo G550 laptop... the problem is that i can get in to BIOS or BOOT menu i've tried every key F2 F12,, nothing works..pls help me..
Try with External USB Key board. To enter BIOS setup utility, press F2 when the Lenovo logo appears during starting up your computer.
Hope this helps to you....
Jun 18, 2011 | Lenovo G550 Notebook
I need windows 7 drivers for lenovo y410....pls pls pls urgent.....
download lenovo thinkvantage system update 4.0 and run it it will grab all your drivers
May 13, 2011 | Lenovo 3000 Y410 Laptop
Booting problem
See 1. hard drive in BIOS. 2. Bootup sequence in BIOS If it`s ok try to reinstall Windows
Apr 10, 2010 | Lenovo 3000 Y410 Laptop
Lenovo y410 bios password missing what can i do the bios unlock
go to the below site and download the pc cmos cleaner. then burn it to a cd. boot from the cd to remove the bios password. pls rate me thanks
http://www.pccmos.com/
Jan 24, 2010 | Lenovo 3000 Y410 Laptop
Install webcam driver but cant find shortcut and unable to open
click on your start button (usually the window logo on bottom left side of your screen)
then click on search then type webcam and press enter . you should get a list and you should be able to click on an item to open web cam. if this works i suggest to repaet theses steps but then copy and paste it somewhere easier to find.
Apr 26, 2009 | Lenovo 3000 Y410 Laptop
Sound goes on & off on lenovo Y410 laptop
Next time it goes off, have a look to see if you have a service/process called Windows Audio running. Click Start & type "services.msc" in the search box (presuming you are using vista), then just press enter.
Look for "Windows Audio" & "Windows Audio Endpoint Builder".
Make sure they are running/started & set to automatic.
The problem could be a driver that did not install properly, a codec that did not install properly or a Windows update that did not install properly.
Feb 12, 2009 | Lenovo 3000 Y410 Notebook
Laptop is not booting
go back into the bios and reset the bios to defaults, hit F10 to save changes and reboot
let me know what happends
regards
Nov 24, 2008 | Lenovo 3000 Y410 Notebook
Problem with touch pad & web cam
did you try FN+F8
you should have disabled your touchpad.
Try this
Nov 04, 2008 | Lenovo 3000 Y410 Notebook
White Screen for Lenovo Y410
can you try and power up in safemode
by continuosly pressing f8 during startup
see if you can get in safemode
Aug 31, 2008 | Lenovo 3000 Y410 (59012354) PC Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
