Trying to find spec sheet on Dell GX270 mainboard with diagram showing pront panel connector specs
Mainboard has 34 pin front panel connection socket I need the specs on that socket with diagram
  • tspelman
    tspelman Dec 03, 2012
    Thank you thats exactly what I needed. Hope one day to help you out with something.!!!
  • 3,606 Answers
  • tspelman
    Excellent answer just what the doctor ordered. Thanks a million!!!
gcrcomputers
  • 170 Answers
SOURCE: front panel connectors
Pin Signal In/Out Description Pin Signal In/Out Description 1 HD_PWR Out Hard disk LED pull-up (330 ohm) to +5 V 2 HDR_BLNK_GRN Out Front panel green LED 3 HAD# Out Hard disk active LED 4 HDR_BLNK_YEL Out Front panel yellow LED 5 Gound Ground 6 FPBUT_IN In Power switch 7 FP_RESET# In Reset switch 8 Ground Ground 9 +5 V Out Reserved 10 N/C 11 Reserved In Reserved 12 Ground Ground 13 Ground Ground 14 (pin removed) Not connected 15 Reserved Out Reserved 16 +5 V Out Power
Hope this helps, , if so please rate accordingly.
Thanks,
David
Posted on Mar 12, 2009
multilinkent
  • 739 Answers
SOURCE: elitegroup mainboard p4vmm2 user manual
Are you use p4vmm2 (v1.1a) motherboard?
Download p4vmm2(v1.1a) manual guide to solve your problems,
==>> (CLICK HERE) <<==
hopefully this are can help
thanks....
Posted on Jul 24, 2010
  • 161 Answers
SOURCE: IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Posted on Aug 12, 2007
  • 5 Answers
SOURCE: i have pront panel audio and usb port but am not
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Posted on Aug 31, 2009
Vanguardian
  • 106 Answers
SOURCE: Need manual
Not exactly the standard MB spec sheet, but this may give you what you need.
http://h18000.www1.hp.com/products/quickspecs/12426_na/12426_na.HTML
Posted on Sep 10, 2009
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
I replace my power supply for my E520 and its dose not turn on. It is a new replacement power supply for this model. I check alll the connections. It haas aa blinking amber light all time.
I would double check the connections to the main board. Some power supplies have two power connectors to the mother board, a 20 pin connector and a 4 pin connector. Sometimes the four pin connector is in a different location from the 20 pin on the board. Make sure both connectors a plugged in.
Make sure the connector for the power switch is plugged into the board. Dell's usually have all the wires for the front pane in one connector.
You should also unplug everything from the board except the power supply and front panel. There could be a hard device causing the board to hang up.
I have had power supplies die and short the main board. I hope that isn't the case here.
Jul 02, 2011 | Dell DimensionTM E520 PC Desktop
Pressing the start button the fans run and the keyboard lights momentarily after 2/3 seconds the fans stop the computer does not start Dell Optiplex gx270 I have the same problem with Phillips MT2400
first, try to replace keyboard. if not work try reformat the system and if still not work, there is a problem in mainboard maybe short circuit then replace mainboard.
Oct 10, 2009 | Dell OptiPlex GX270 PC Desktop
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Foxconn LS36 mobo , front panel (34pin) connection DETAILS needed
Dell has never published the pin-outs of their proprietary ribbon connectors to the front panel
Jun 03, 2009 | Dell OptiPlex GX270 PC Desktop
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Proper pin numbers to install inserts in a Dell SATA 34 pin GX270 motherboard
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
May 20, 2009 | Dell OptiPlex GX270 PC Desktop
why do you need the IDE cable pin out if you are using SATA?
they are diiferent and not interchangeable. if you want to use IDE pin out for SATA, then you need to get a adapter from IDE to SATA.
May 19, 2009 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
