Question about Kenmore 75022 / 75024 / 75029 Gas Kitchen Range
Kenmore capri gas stove
Oven door has gap at top
Macmarkus
  • 2605 Answers
SOURCE: Kenmore gas stove, broiler works but oven won't
Hello, I'll start by saying this may sound odd considering the info you provided, "ignitor glows...". It is actually the ignitor you'll need to replace. Being that I do service for sears I've replaced numerous ignitor's, both bake & broil, but bake being most common as it is typically used more frequently. I'll try to explain... The simpliest way to put it is this, the hot surface ignitors function like a large resistor. As the ignitor glows it reaches a value to allow the gas valve to open and lite the burner. If the ignitor is even slightly worn/off it won't ignite the burner, hence it need's to be replaced. Hope that help's explain what & why. If so please take a second to rate the solution I provided here at fixya. Good luck and thanks for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
fridgetech
  • 473 Answers
SOURCE: Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Posted on Oct 16, 2007
milten1
  • 1304 Answers
SOURCE: kenmore stove oven not on
sounds like an ignitor
you may need a service man
but the parts run around 60-75 dollars
just a heads up
Posted on Oct 06, 2009
  • 31 Answers
SOURCE: I have a Kenmore Elite Gas Range. #790 series.
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Posted on Jan 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore gas stove model 790, the oven will not
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
W'house gas oven GXR650SNG. The oven bleeds heat from a gap at the top of the casing, above door, below panel. Never hot enough to cook. What's missing? A seal? Cheers
You really need to have a professional look at this because gas stoves are nothing to fool with, can be very dangerous
Apr 28, 2017 | Ovens
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 | Ovens
Ilve oven door adjar with a gap at the top
Yes but try removing the door usually a small lever on the hinge or just lower the door a bit and lift it off. Then put it back on and make sure it sits back down into the hinges. We had one that did the same thing and the door was just a bit out of the hinge.
Apr 09, 2010 | Kitchen Ranges
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Logo
256 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
