Question about Grilling
I need a part for my gas BBQ grill, HBT250B. Where can I find a parts list and order information?
I need to replace the metal plate that covers the burner on HBT250B.
SOURCE: Need a Manual & Parts List - BBQ Galore Turbo STS 4 Burner (LP)
I have the manual you are looking for.
Send me your email address and I will send it to you.
rayh2o@yahoo.com
Posted on May 25, 2009
  • 46 Answers
SOURCE: bbq regulator
should be able to get some help at your local hardware or home & garden store!
Posted on May 31, 2009
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Posted on Jun 13, 2009
woodchuck789
  • 4070 Answers
SOURCE: do i need to cover the burner and drip guard over with lava rocks
So you don't have a lower rack for the rock to set on? Mine did and you just have one layer covering the entire surface.
Posted on Aug 02, 2009
cadesertmax
  • 274 Answers
SOURCE: bbq burner flame too high
If you got water down inside the burner(s), this condition should eventually clear up.
Posted on Jan 10, 2010
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
My husband and I inherited a Charbroil gas grill (model # 4639171) from his mother. There is no flame diffuser, heat plate, or lava rocks over the burners. It is difficult to cook on because anything...
I searched my parts catalog for your model number and came up empty. I believe that I may have parts that will work for you. The closet model number to what you have listed is #4639122. This model takes the angle shaped flame tamers. This model also lists a briquette grate. You can go to my website, www.minxenterprisesinc.com and check out this model number and it will give you dimensions for the parts. You can see if they will fit. I would not get lava rock, purchase either ceramic or porcelian briquettes, as they work much better.
Jul 16, 2011 | Char-Broil Grilling
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
My charbroil bbq had a metal part above the burner that has now broken and i need a new 1 do you know where i can get 1 and what the part is called
Hello, Yes, It's called a burner shield. You can go to this link and order what you need. http://www.grillparts.com/charbroil/masterflameparts.htm
You'll need to select which model series # it is and if it was made from before or after 1999, in order to bring up the correct parts list for your model. Then you can find the shield in the parts list and order it online from this parts supplier. Have a great day!
May 18, 2010 | Char-Broil CharBroil Master Flame Gas...
Change the igniter on a thermos bbq
You may not have to change the igniter. It works like a spark plug (passing a small spark from an electrode (a small wire sticking from the bottom of the ceramic tube at the lower end of the igniter) to a metal plate positioned close to the tip. If the plate gets covered with soot or grease from cooking it won't work. Try cleaning the plate and bending it closer to the igniter tip. If the igniter is really bad and needs replacement, you can get a new one at most hardware stores. Installation is very easy.
Apr 22, 2010 | Thermos Stainless Steel Gas Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
Grilling Logo
48 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
